I think its a mis typo 18 is axel code and the 3 maybe the tape code. if so here is what I have.
Axle code:
F-150/250/350 non limited slip:
Code...Man...Size...GVW..Gear Ratio
18......Ford....8.8"...3750...3.08
I realize how ancient this thread is, but there didn't seem to be a logical conclusion re: code 183. The info regarding 18 makes sense, 8.8 w/ 3.08 but my label also states 183 (1986 F150, 300, TOD 4 sp OD, 8.8 rear end). Was it common for Ford to have a typo on a vehicle label and replicate that mistake for tens of thousands of vehicles? If anyone is still around, could you elaborate on the definition of "tape code." Thanks.
That explains it. It was empirical that on the door jamb Manufacturers Label, in the box labeled Axle Code, that my truck (and many others on this thread) was 183. It's not a typo. And even though we know Axle Codes are two characters, this clearly has 3 characters. Thanks for the cipher and the deep Ford knowledge. Much appreciated.
I am glad you are satisfied. I don't get how the power steering delete code could be in the rear axle ratio box, but we will go with it. Do you guys with the "3" all have manual steering?
The axle code is "always" broken down by 2 digits for the rear, the 3rd for the front. In some years there is no front code when it is a standard axle.
Some of the codes have alternate meaning, usually made "clear" by the wording and date ranges etc.
I know the Ford literature says that the 3 is for power steering delete, but people have shown up various times over the years with a "183" axle code, and the trucks always have power steering. One of the old Ford dealer guys...maybe it was Bill/Numberdummy said that the 183 code was a mistake, and that there never was a power steering delete code on these trucks. However, they do show up every now and then with that code.
I know there were trucks earlier on (all 2wd) with manual steering, but it was never indicated on the Certification label.
