return line
Old Feb 3, 2006 | 12:03 PM
77effie's Avatar
77effie
return line
i am fabbing up a return line for my sefi motor and wondered if i need to use high
pressure efi rubber hose or if i can get away w/ standard fuel hose
Old Feb 3, 2006 | 12:55 PM
Steina's Avatar
Steina
CO River Rat
The ProJection kit I installed on a 350 Cheby had only FI hose for pressure and return, so I ASSUME (yeah, I know) FI hose would be the way to go.
Steve
Old Feb 3, 2006 | 01:17 PM
77effie's Avatar
77effie
i figured so ... i just hate the $6 per foot thing, need a tank that will pressurize also ?????
Old Feb 3, 2006 | 01:26 PM
Steina's Avatar
Steina
CO River Rat
Yeah, that stuff ain't cheap but it will probably outlast the truck! Are you putting in hard-pipe except at the engine and tank? The gas tank needs to be vented.
Steve
Old Feb 3, 2006 | 01:42 PM
77effie's Avatar
77effie
i an useing the stock tank in a '77 the feed line i am useing 6 feet of -8an earls steel braided ( cause i got if for cheap along w all nessary fittings) and then running rubber line the rest of the way to the fuel pump (in line)
Old Feb 3, 2006 | 02:50 PM
Steina's Avatar
Steina
CO River Rat
Somethin' I just remembered from that ProJection install on a '78 Regal; the return line hooked to an emissions fitting on the tank, but I had to knock out a restrictor in the fitting to ensure proper flow back to the tank. Might be worth checking into.........
Steve
Old Feb 3, 2006 | 03:10 PM
77effie's Avatar
77effie
good ideas/info
Old Feb 6, 2006 | 11:19 AM
77effie's Avatar
77effie
i chicken'd out and bought a carb !!!!!!!!!!!!! edelbrock 600 ...25' foot of good year
rubber fuel hose ...$19 only one line to run priceless
Old Feb 6, 2006 | 12:03 PM
Steina's Avatar
Steina
CO River Rat
Did you need to do any tuning on that carb? If I remember right, Edelbrock uses metering rods which can be a PITA.
Steve
Old Feb 6, 2006 | 12:33 PM
77effie's Avatar
77effie
nope it works great ...so far... the metering rods are easy as pie and the jets are easier to change than holley i did a lot of reading up before i bought the edl ....
i got the #1405 manual choke... i am shure it will need some minor tuning ... i plan on adding a fuel ratio meter so i can keep a visual on things ...
i just dont have the time to fab up all the small stuff it would take to run efi w/ out haveing a kit for my specific application ...it could be done pretty easy i just dont have the time to invest .....i was just ready to crank it and go
