Yeah, that stuff ain't cheap but it will probably outlast the truck! Are you putting in hard-pipe except at the engine and tank? The gas tank needs to be vented.
i an useing the stock tank in a '77 the feed line i am useing 6 feet of -8an earls steel braided ( cause i got if for cheap along w all nessary fittings) and then running rubber line the rest of the way to the fuel pump (in line)
Somethin' I just remembered from that ProJection install on a '78 Regal; the return line hooked to an emissions fitting on the tank, but I had to knock out a restrictor in the fitting to ensure proper flow back to the tank. Might be worth checking into.........
nope it works great ...so far... the metering rods are easy as pie and the jets are easier to change than holley i did a lot of reading up before i bought the edl ....
i got the #1405 manual choke... i am shure it will need some minor tuning ... i plan on adding a fuel ratio meter so i can keep a visual on things ...
i just dont have the time to fab up all the small stuff it would take to run efi w/ out haveing a kit for my specific application ...it could be done pretty easy i just dont have the time to invest .....i was just ready to crank it and go
