Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Brake jobs
Old Apr 28, 2004 | 10:10 PM
Sberry27's Avatar
Sberry27
I can buy new wheel cyls from the jobber for 10$, we put new ones and new hdw on all jobs anymore.
Old May 2, 2004 | 07:52 PM
DiGoogs's Avatar
DiGoogs
Might be **** but:
I put "speed nuts" on the front rotors on my 4WD X's. Holds things in tight as the rest goes together. I also torque the wheel nuts. I heard that helps prevent rotor warp .... (I don't know if that is possible on "the new" rotors)
Old May 2, 2004 | 08:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
According to the factory manuals they are supposed to have speed nuts or retaining clips on them. Most brake shops don't put them on after they do a brake job. Makes a hell of a mess when you are out in the dark in the dirt and the hub falls off when you pull the wheel. How do you say "dirt in the bearings" much less where did that little sealing O-ring go...
BTW- You can buy those little retaining clips for $.25 each at the hardware store out of those little plastic drawers. I don't know how much 1/2" or larger speed nuts are. You can buy big O-rings at any local hydraulics supply house.
You can find O-ring specs here: http://www.parker.com/o-ring/Literature/00-5700.pdf
ruschejj
6.7L Power Stroke Diesel
15
Jan 23, 2014 07:21 PM
sammyhawk
1997 - 2003 F150
Aug 22, 2012 07:46 AM
RojoStar
Aerostar
Feb 6, 2012 12:29 PM
Neil64
Apr 6, 2010 10:19 AM
Greywolf
Feb 17, 2004 10:09 PM
