Clutch Problems
Old Feb 2, 2006 | 07:14 PM
rhowell's Avatar
rhowell
Clutch Problems
Ok a while back I changed the clutch disc out in my 94 B3000 and before it went out the feel of the clutch and response was good, after i changed it and put it back together it has a weak feeling to it but pretty much engages and disengages the same, if anybody has had this problem or has any ideas please leave a reply
Old Feb 3, 2006 | 06:31 PM
Ken00's Avatar
Ken00
Can anyone comment on this question.
Old Feb 3, 2006 | 10:08 PM
jorlee's Avatar
jorlee
You might have some air in the hydraulic system yet. I'd suggest trying to bleed it again. Just make sure you go really slow when your bleeding it. Might try leaving the bleeder screw open a little and just slowly work the pedal, an inch for a couple pushes then go 2 and so on. Then bleed it normally. Other than that I can only put forth uneducated guesses.
4inchlovin
Aug 10, 2013 10:16 PM
green84f150
Jun 9, 2007 02:11 AM
vmaxvboost
Bronco II
Jan 7, 2007 01:00 PM
niteowl
Jul 20, 2004 10:40 AM
Levergun
May 10, 2004 04:41 PM
