C6 HELP!!! New Update
Old Jul 8, 2001 | 01:13 PM
eraser60's Avatar
eraser60
08-Jul-01, 00:14 AM
I let the truck cool for a couple of hrs, and the transmission went right into gear. After it warmed up, the same problem occurred.
jeff
I just put a C6 out of a parts truck into my 70 F250. Feel
confident that I had the torque converter all the way in. Nearly
an inch behind the front of the bell housing, and the transmission mated right up to the motor with no problem. When I start up, the transmission went right into gear, no problem. Started down the driveway, and felt something bind up briefly. I stopped, and it clear up. Continued on, every thing seemed great, for about 500 yards, and then it went out of gear. Now every gear is like it's in neutral. What do you think, could it be the torque converter, or is the transmission finished.
thanks
jeff
Alert Edit | Reply | Reply With Quote | Top
MEPHISTO_XES
Non-member
07-Jul-01, 08:59 PM
Might have shered the ears off the trans pump. It's fixable though. Chk and make sure the fluid level is right first. They
take alot if the converter has been drained. If the level is where it should be, ya may had well start pullin.
Remove | Alert Edit | Reply | Reply With Quote | Top
Old Jul 8, 2001 | 01:50 PM
eraser60's Avatar
eraser60
I read in one of my motor manuals that no drive in any gear
could be the valve body, or the pressure regulator? Where is
the regulator. Is it replaceable with the tranny in the truck, or is it internal meaning a tranny tear down to get to. Truck has all gears for about 5 minutes when started from cold, then looses all gears.
thanks
jeff
Old Jul 8, 2001 | 05:52 PM
classic79's Avatar
classic79
How long has this tranny sat without being used?
I assume the fluid is in good condition and at the proper level?
I swapped a supposedly good c-6 into a 67 stang once, had same symptoms you have. ended up being the clutches were all shot apparently from sitting for a long period of time. Did a simple rebuild and its still going strong today.
Chris
79 F-150
79 mustang
Old Jul 8, 2001 | 08:53 PM
jowilker's Avatar
jowilker
Jeff, You are still new here, but don't start a second thread on the same subject, while the other is current. We will try to help you with your problem.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Jul 8, 2001 | 09:00 PM
Franklin2's Avatar
Franklin2
firecatab
6.4L Power Stroke Diesel
Sep 20, 2010 05:31 PM
111900
Mar 24, 2006 06:10 PM
msujon71
Aug 16, 2001 02:16 AM
orangepeel
Jul 4, 2001 07:26 AM
eraser60
Mar 2, 2000 10:14 AM
