Not sure what this is?
Old Feb 1, 2006 | 10:04 PM
rclark1's Avatar
rclark1
Question Not sure what this is?
I just finished installing new headlamps ( with the the help of this forum's members) and while I had the front end apart I noticed a large plug in with a plug in it. It was located near what looks a larger heat sink approx 3"x5" large fins on it. The plugged plugin fit right into this after removing the plug from the plug in. Approx 7 or 8 wires running to it. Have not noticed anything different after plugging it in? any Ideas what this is?
Old Feb 1, 2006 | 11:40 PM
mjwhip2's Avatar
mjwhip2
Oops, reread and now I don't know what you're talking about.
Old Feb 2, 2006 | 06:27 AM
tjbeggs's Avatar
tjbeggs
daytime running light module. did you say the module was not plugged in? mine has the plug but no module
Old Feb 2, 2006 | 09:50 PM
rclark1's Avatar
rclark1
Talking
You are right, it had a rubber plug in it to prevent dirt and water from clogging. So after you said that I noticed that the lights are on now anytime the key is on.
Thanks
Old Feb 2, 2006 | 11:19 PM
pulnhorses's Avatar
pulnhorses
What year is your truck? Mine is a 97 crew PSD.
Old Feb 7, 2006 | 11:49 AM
Tx_Atty's Avatar
Tx_Atty
did you happen to take any photos?
Old Feb 7, 2006 | 12:58 PM
1997F-350's Avatar
1997F-350
the plug for the drl module is right behind the bumper on the drivers side up a few inches. get under you truck and look up under it to see where the plug goes into. most (99%) of the trucks out there dont have the module you gotta find one in a junkyard or buy one. but if you plug one in you will have DRL.
Old Feb 8, 2006 | 05:32 PM
pulnhorses's Avatar
pulnhorses
Thanks a bunch, found the plug but not the module. I'll check the junk yard and see what I can find. Thanks again!
Old Feb 9, 2006 | 04:00 PM
Tx_Atty's Avatar
Tx_Atty
Does it look like this?
http://cgi.ebay.com/ebaymotors/DAYTI...spagenameZWD1V
Old Feb 9, 2006 | 10:32 PM
Phydeaux88's Avatar
Phydeaux88
What lights does it turn on?
Old Feb 9, 2006 | 11:40 PM
rclark1's Avatar
rclark1
Headlights
Old Feb 10, 2006 | 07:09 PM
444dieselrod's Avatar
444dieselrod
A module from any Ford vehicle should work also.
Diesel Rod
