Weird Speedometer
Old Feb 1, 2006 | 06:13 PM
mowakebum's Avatar
mowakebum
Weird Speedometer
I've got a 93 Explorer Sport 2wd. My speedometer is acting up. Every now and than it starts shaking when I go above about 45 mph. This just happened occasionally when I first bought it. I got it with 55125 miles on it. Any ideas on what could be causing it. ?
Thanx
Old Feb 1, 2006 | 07:48 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 2, 2006 | 10:10 PM
texan2004's Avatar
texan2004
Thanx
If you have a cable with a gear on the end, either the cable is kinked or the gear is starting to go. I suspect you have a seppd sensor on your tranny however and that could be what's going bad. Any other things it's doing that may seem weird. Reason I ask is that the speed sensor data to the PCM can effect many things. Another possibility is that your speedometer is bad or that somebody screwed with it before you bought it (read: rollback)
KsHighboy
Jan 26, 2017 11:21 AM
Countryford83
Jul 30, 2015 08:59 AM
JacobRM
19
Jun 3, 2014 06:35 PM
Loganc95
Jun 10, 2013 02:43 PM
fordbroncodave
1978 - 1996 Big Bronco
Dec 8, 2011 08:07 PM
