Explorer door will not open/close properly
Old Jan 26, 2006 | 12:47 AM
harringp's Avatar
harringp
I've got a 98 Explorer Sport and the driver's side door will not open and close properly. Every time I try to close the door I have to use a screwdriver to pry up the latch (as I'm raising the handle). I don't know much (or anything) about car repairs but don't have a lot of money to pay a repair shop. Does this sound like something I could do myself? If so, how would I go about doing this?
Old Jan 26, 2006 | 07:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 26, 2006 | 10:22 AM
Keato's Avatar
Keato
Wink
Sounds like maybe you broke the springs in your handle or maybe the linkage in the door is bent. I had something similar happen to my '98 Sport.
Depending on how confident you are it's possible to repair yourself if that's the problem. It requires removing the door panel and drilling out the handle rivots. I would make sure that's your problem though, and picking up a Chilton's will help you out. I used a Haynes but the pictures and directions seem to be better in Chiltons if you can find them. Goodluck
Old Feb 1, 2006 | 05:40 PM
vicv's Avatar
vicv
Clean the latch mechanism with electronics cleaner really well too. The latch could be gunked up so much it's hanging up. Then spray lube at every oil change.
Old Feb 2, 2006 | 10:14 PM
texan2004's Avatar
texan2004
A body shop may take some mercy on you and fix this for next to nothing if you are not confident in doing it yourself. IT's really not that difficult complexity wise but it can be a pain to access.
JRD761
6.7L Power Stroke Diesel
Sep 26, 2016 08:57 PM
kev100
17
Apr 21, 2016 05:05 AM
yellowboy
2004 - 2008 F150
Dec 27, 2015 05:16 AM
Redneckfordf2502002
Jun 3, 2013 10:05 AM
ham-n-swiss
Jun 27, 2008 02:19 PM
