Clutch squeaking when depressed
Old Feb 1, 2006 | 06:07 PM
ColonyPark's Avatar
ColonyPark
Another weird problem with the Ranger (97 4x2 SuperCab XLT, 2.3, 5 Speed). The last little while, there is a squeaking noise when I depress the clutch petal. It's almost a honking sound. It seems to be getting worse instead of better. What in the world is it?
My first thought would be a cable, but since this has a hydraulic clutch, I'm a little stumped. The sound *seems* to be coming from outside the cab, either through the firewall or the bell housing area. They're close together, so I'm not completely sure.
Is this something you've heard?
Thanks!
Old Feb 1, 2006 | 06:16 PM
pintopower8's Avatar
pintopower8
Hey man I have the exact same issue> my truck is also a 97' with the 4.0L. Its coming from the throwout bearing area. I took off the peep cover. I don't know what exactly it is but I still have a used vehicle warranty so I'm gonna get it checked out. My trucks had a new clutch put in it before so I don't know if its a 97' thing or not. Theres a spring in there with the throwout bearing, I almost think that thats whats doing it.
Old Feb 2, 2006 | 02:02 PM
ColonyPark's Avatar
ColonyPark
Oddly, mine seems to come and go, and I think temperature is sometimes a factor. For example, yesterday it honked all day, but this morning when I was on my way to work, I never heard a peep. It was colder this morning than yesterday, so who knows.
Old Feb 2, 2006 | 04:32 PM
pintopower8
yeah same thing here
Old Feb 2, 2006 | 07:14 PM
natebaker's Avatar
natebaker
Same here on my 99 2.5L L4. Sporadic enough to annoy me, lol.
Old Feb 2, 2006 | 08:46 PM
pintopower8
So I guess its not just a 97' problem
Old Feb 2, 2006 | 10:24 PM
natebaker's Avatar
natebaker
Nope.... I wish it was, lol jk
Old Feb 2, 2006 | 11:20 PM
agryphon's Avatar
agryphon
I have seen a clutch master cyl on older cars make a squeeky honking sort of noise when the seal around the pushrod leaks a little...
Old Feb 3, 2006 | 09:18 AM
mds79's Avatar
mds79
Pushrod
Check to make sure your pushrod that goes from the clutch pedal to the master cylinder is not sliding against the sleeve that goes thru the firewall. That was my problem. The rod was just about unscrewed from the pedal and was very crooked. Straigtened it back up and it was much better.
Old Feb 3, 2006 | 12:04 PM
ColonyPark's Avatar
ColonyPark
That sounds like a very likely source! I can hardly wait to go look at it. I'll let you guys know what I find.
CJB
