Axle question
Old Feb 2, 2006 | 05:20 AM
fd1109's Avatar
fd1109
I had the problem of the rear "biting" on tight turns. Changed fluid with 75w-90w Amsoil with friction modifier from ford. There is a Ford update telling to use 75-90 if there is a problem with the clutches "biting". It worked for about 25,000 miles and are starting to "bite" again. I guess I'll change it again when I do the anti-freeze.
Old Feb 2, 2006 | 07:37 AM
guzzle92's Avatar
guzzle92
Originally Posted by JOE-M
Have you reached the 100k mark? Is that why all the maintenance work? Mine is at 97k and I'm dreading the time and cost on the coolant and the rear ends.
No, only about 63K here. I just think some of Ford's intervals are a little too long. Coolant will be a piece of cake compared to the axles but I won't do that until I get closer to 100K.
Old Feb 2, 2006 | 07:54 AM
mjtpolice76's Avatar
mjtpolice76
great write up thanx for all the help
KingBigJoe
30
Jul 12, 2020 03:24 AM
barisotero03
Dec 10, 2013 03:23 AM
RedDoorRestos
Feb 15, 2007 07:26 PM
2valvekid
1983 - 2012 Ranger & B-Series
Dec 29, 2005 03:53 PM
