F350 4wd tie rod setup
Can anyone tell me how the tie rod and drag link are setup on a 94' F350 (Dana 60) 4wd?
Is it like the F250 (Dana 50 IFS) TTB? Drag link from pitman arm to knuckle and tie rod from draglink to knuckle. Or is it setup with a tie rod from knuckle to knuckle then a drag link from the tie rod to the pitman arm.?
Any info please.
Thanks
Any info please.
Thanks
Pitman arm to sleeve to tie-rod, that goes to RH connecting rod(goes to r.knuckle) RH conn. rod to sleeve to Left outer tie-rod. This is 85-97 F-350. 80-96 TTB,Pitman arm to RH conn.-rod to sleeve to R. knuckle,L.inner tie-rod from RH conn. rod to sleeve to L. outer tie-rod.All straight axles/MONO-beams run knuckle to knuckle.
ssi9620
07-16-2015 10:27 AM
Road Warrior 95
07-05-2014 09:55 AM
jbrown9709
04-04-2009 07:28 AM
