99 expedition engine trouble
Old Jan 31, 2006 | 10:03 AM
tntwisner's Avatar
tntwisner
I just changed my spark plugs and now when I hit 40 mph and it shifts and the rpms lowere it shutters. what could be doing this
Old Jan 31, 2006 | 01:34 PM
projectSHO89's Avatar
projectSHO89
Need more information.
Which engine.
Which brand and part number spark plug did you use.
It's a misfire under load. If you didn't have one before, this problem is most likely due to a bad connection (plug wire, COP, injector, etc). If it was there before, it's most likely a wire or COP.
Steve
Old Feb 1, 2006 | 06:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome tntwisner to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 10, 2011 | 12:42 PM
jnoble5729's Avatar
jnoble5729
I am having the same issue with my expedition. So it is a COP, or wire, how can I determine what one it is? Each COP is over $40 a piece so I don't want to change them all out if I don't have to.
Old Apr 10, 2011 | 06:52 PM
projectSHO89
Please don't bring old threads back from the dead unless they are VERY relevant....
Old Apr 10, 2011 | 08:46 PM
LxMan1's Avatar
LxMan1
Swap the offending coil to another cylinder and see if the code follows the code.
Old Apr 16, 2011 | 06:17 PM
green 1969 f100's Avatar
green 1969 f100
Did you use Motorcraft plugs?
Old Apr 17, 2011 | 09:14 AM
projectSHO89
Um, that was FIVE YEARS AGO!
Old Apr 21, 2011 | 04:51 AM
JWA's Avatar
JWA
These same issues occur regardless when they happened to the OP----its relevant in that way 100%!!
Old Jul 17, 2011 | 01:14 AM
requience139's Avatar
requience139
Extremely relevant since my truck is doing this. Now I highly doubt the OP will answer back
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
