Another diff ratio question.
Old Aug 11, 2015 | 10:35 AM
tiger100's Avatar
tiger100
My 51 F1 has 427 stamped on the passenger side rear axle tube. I jacked up one wheel and market the tyre and drive shaft and gave the wheel a spin. For two revolutions of the wheel the drive goes 'round approx 4 and a quarter times.Being inquisitive I had to have a look inside, the numbers on the crown wheel? are 1M4210-B and 11x47 and 1-51 and a C.
It looks like there are several chipped teeth on one of the Planetary? gears and the bolts holding the bearings weren't really done up properly.
(1) Is this diff higher ratio than most F1's or a super low ''tree climber''.
(2) If its a higher ratio than normal would it be better to replace chipped teeth etc, than to take a chance on a 9'' 28 spline Ford diff that's an unknown?
(3) Can someone tell me the torque settings for the bearing caps, please.
Once again, Thanks to each and everyone who answers.
Geoff.
Old Aug 11, 2015 | 11:03 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Geoff.
The F1 had two gear ratios available, 4.27 and 3.92.
Old Aug 11, 2015 | 04:53 PM
38 coupe's Avatar
38 coupe
If your gears are chewed up you probably should replace them, along with the bearings in the area. Or find another F-1 axle from someone hot rodding their truck. If you want to rebuild and re-gear your stock axle it can be done but the parts are expensive.
Old Aug 14, 2015 | 08:51 AM
tiger100's Avatar
tiger100
another Diff ratio question
Jolly Roger Joe and 38coupe, thanks for the answers to my post.
I appreciate the fact that I would have to replace chipped gears etc, IF I was going to re-use this diff. and i understand that to regear it would be expensive......something about these old trucks is cheap?
However this doesn't answer my questions.
Surely someone has the answers......
Geoff.
Old Aug 14, 2015 | 09:55 AM
52 Merc's Avatar
52 Merc
What question? As the others stated, your gear ratio is common (normal), depending on which option box the original purchaser checked. Getting the same or different gears in a used axle assembly is a crap shoot. There were only a couple of options. You've noted your gears are chewed up and your bearings are loose, so your axle is essentially junk. If you're going to rebuild it yourself, get a shop manual so you have the instructions and specifications you need for reassembly. Or are these just not the answers you wanted to hear?
Old Aug 14, 2015 | 12:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No matter how you address the problems, I'd figure on it costing you $700 - $1000. That's whether you have the existing axle rebuilt, put in a well-used 9", go with Explorer, etc. So decide what you want to end up with first.
Old Aug 14, 2015 | 02:21 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Hi Geoff, a picture may be very helpful for the guys trying to help you diagnose your problem. If your tube is stamped 427 odds are that you have the 4.27 gear option, If you still have the cover off and can snap some pics of what you are describing it would allow them to give you more informed answers. As I understand it the higher the # the lower the gear, the lower the # the higher the gear. Best of luck on your rear end. If you do not know how to post a picture click on the third READ FIRST thread on the top of the main page. It explains how.
Old Aug 15, 2015 | 07:48 AM
38 coupe's Avatar
38 coupe
I don't have manuals in from of me to go into more detail. I highly recommend purchasing a copy of the shop manual for your truck, it is very helpful (for example it will go through disassembly and reassembly of your axle).
The question of gearing in the Dana 41 and Dana 44 axles has some history on this site. Here are three threads that you will probably find helpful:
https://www.ford-trucks.com/forums/1...ar-change.html
https://www.ford-trucks.com/forums/1...-rear-end.html
https://www.ford-trucks.com/forums/1...-finished.html
Cobravii
Jan 11, 2019 05:23 PM
FF34
Apr 7, 2014 10:15 PM
nstueve
Jun 30, 2009 08:29 AM
ljbrown
All Things Towing
Mar 22, 2007 12:11 PM
freezeplug
Jul 17, 2003 09:01 AM
