Need help with headlight replacements??
Old Jan 30, 2006 | 03:36 PM
rclark1's Avatar
rclark1
Unhappy Need help with headlight replacements??
I just bought a new set of Glass headlights (not Bulbs) as the originals are very pitted.
But dummy me I can not seem to get trim and such removed in order toget the old ones out. Any help would be appreciated.
97 F-250 7.3 Old Body style
Old Jan 30, 2006 | 05:30 PM
rclark1's Avatar
rclark1
Any Help Please,
Old Jan 30, 2006 | 06:33 PM
jimkidd's Avatar
jimkidd
Door, Headlamp
Removal
1. Remove two screws and nuts retaining headlamp door (13064) to radiator grille opening panel reinforcement (8A284).
2. Pull headlamp door from vehicle.
3. Remove three bulbs and sockets from headlamp door.
4. Remove headlamp door.
Installation
1. Follow removal procedures in reverse order.
2. Tighten screws to 1.4-2.3 N-m (13-20 lb-in).
Headlamp Door
Old Jan 30, 2006 | 06:49 PM
rclark1's Avatar
rclark1
Thanks a million, You're a life saver
Old Jan 30, 2006 | 07:24 PM
jimkidd's Avatar
jimkidd
Anything I can do to help.
jimbo
Old Jan 30, 2006 | 08:35 PM
rclark1's Avatar
rclark1
JimKid , Afraid I spoke to soon.
Got the lock reatiners and even removed the grill, but the bottom corner of the trim just won't come loose. I sure this is muck easier than I have made it
Old Jan 30, 2006 | 08:50 PM
HTRDLNCN's Avatar
HTRDLNCN
I had to remove the batteries to get at the back of the trim pieces
Old Jan 31, 2006 | 12:02 PM
plowhand's Avatar
plowhand
Playing in the Dirt
There are two screws holding the top of the headlight door on. These are easy to see. There are also two studs, one lower outside corner and one middle inside. Reach behind the headlight assembly where it attaches to the radiator support and feel for the the two nuts. A 1/4" drive rachet and deep well socket is used to remove the two nuts. I think they are 11mm, but not sure. Look on the picture that Jim Kidd posted and you can just make out the two studs on the back side of the assembley. Hope this helps.
Old Jan 31, 2006 | 12:05 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Update: on the picture the screws are 2B and the nuts are 9A
Old Jan 31, 2006 | 12:10 PM
HTRDLNCN's Avatar
HTRDLNCN
I had to remove my batteries to get at those..
Old Feb 1, 2006 | 09:57 PM
rclark1's Avatar
rclark1
Smile
Thank you all
Finally got the new headlamps installed and it makes quite a difference
