Wheel size?
Old Jan 30, 2006 | 12:42 PM
kel1306's Avatar
kel1306
Wheel size?
My 73 F250 has a closed knuckle Dana 60. The factory rims are 16.5 inch. Was wondering if 16 X 8 aluminum wheels have enough clearance to fit onto this axle?
Old Jan 30, 2006 | 01:13 PM
1975Ford's Avatar
1975Ford
Yes a 16x8 aluminum rim should bolt on, the problem I have seen is on some model of 16 x 8 inch rims is the center hole in the center of rim sometimes is too small. Also some 16x8 inch rims are made with a larger lug nut holes.
Old Jan 31, 2006 | 02:48 PM
tomcasino's Avatar
tomcasino
My old '75 F250 had the same front axle. The original wheels were the 16.5 split rims. I got rid of those right away. With drums on four corners I was able to run 15 x 8 steel spoke rims with no problems.
gblaz123
May 14, 2011 10:19 AM
STRETCH222
Aug 15, 2008 04:09 PM
scottie2hottie
Sep 26, 2007 12:30 PM
14u2nv
Mar 6, 2005 10:32 PM
Chuck P.
Mar 24, 2000 03:26 PM
