Can someone give me an ideal how much a
05 F350 4X4 CC LB V10 auto will weigh?
Wondering if it's to much for my 9000lb lift in my home shop to lift?
Thanks
Gene
Weight wise you are OK. Your truck should be about 7000 pounds empty. Balance is another consideration. Is your lift 4 post or 2 post? Balancing such a long wheelbase vehicle with the weight concentrated in the front can be tricky on a two post. Also be careful about headroom as these trucks are tall.
Thanks men!
I thought maybe 9-10,000 lb?
I've owned 4 SD's sence 1999 and 3 of those were diesel but never
really paid much attention to their weight...other then I knew they were heavy!
And yes it is a 2 post lift, which is also just a few weeks old
I can asure you I'll triple check the balance before getting it to far off the floor!
Again thanks for the quick replys!
Gene
