Transmission Sludge?
Old Jan 30, 2006 | 07:12 AM
Nitramjr's Avatar
Nitramjr
I have a '97 F250 HD with the 5.8L and E4OD trans. I have had the truck for 1.5 years and it has about 128,000 miles. Since I had no idea how old the fluid is in it I decided it needed to be changed. It looked pretty clean on the stick and didn't have a burned smell.
After removing the pan I found a donut shaped magnet stuck to the inside. I assume it belongs there. When I removed it from the pan it felt like it was covered with grease. It's hard to describe exactly how much but say maybe 1/8" coating all over it. The fluid still looked clean and the inside of the pan was clean.
Now, my question. Is this normal? I'm sure the magnets job is to pick up metal that has worn off the transmission components but I have no idea to what degree is cause for concern. The transmission shifts fine, doesn't leak and the truck is in great shape. Just wondering if I need to start saving for a tranmission rebuild.
Thanks for any responses and opinions.
Ray
Old Jan 30, 2006 | 09:06 AM
stuart1's Avatar
stuart1
Wipe the magnet off real well. Install a filter and fresh fluid. An inline filter may be a good option too.
Old Jan 30, 2006 | 09:43 AM
Casey's Avatar
Casey
Originally Posted by Nitramjr
Is this normal?
That is a normal amount of sludge on the magnet. You don't have anything to worry about.
Old Jan 30, 2006 | 09:52 AM
Nitramjr's Avatar
Nitramjr
Thanks guys. That's what I was hoping to hear.
jeffreyt
419
Apr 12, 2026 05:56 PM
lablue96
Mar 13, 2015 05:44 PM
krifenbu
Jun 9, 2014 08:42 PM
pawpaw
1983 - 2012 Ranger & B-Series
17
Apr 26, 2014 08:52 PM
DRM2004
2004 - 2008 F150
57
Feb 22, 2009 09:13 AM
