'73 F100 H-Pipe?
'73 F100 H-Pipe?
Gotta '73 F100 w/ 390. my exhaust consists of true duals out right before the rear axle w/ flow original 40's. my question is what exactly does an H-pipe do for ya? just equalized the flow from both banks? thanks
Thanks for the help.
Originally Posted by kens64
Balance flow, and mellow the exhaust tone. Also worth a few ft/lbs if done right.
Let's assume we're talking about an Edelbrock system...complete left bank/right bank separation from air cleaner to exhaust on a relatively stock, non-smog 460.
This is a learning curve for me. I was once told by a buddy that owned a muffler shop that cross-overs caused more trouble than they were worth, due to vibration crackes and leaks, but I'd really like to know. In my mind's eye I would think that cross-overs would cause back-pressure rather than alleviate it...but my mind's eye has been wrong before.
Thanks for the help. Any thoughts on this matter are appreciated.
Yup, 351M has it right.
quehele- sorry, typo on my part, I was doing 1000 other things while I was typing
It helps with scavenging, and as a result will build a small amount of torque. The key is placement. Putting it in the wrong place will do nothing.
the reason you put the crossover in is to balance the flow....on a v8, for instance, if you put all 8 seperate pipes, each cyl. will blub out (is that a technical word) on its own. if you put two in each pipe, they will kinda of compliment eachother, assisting the exit of exhaust. if you combine all eight, it smoothes out the flow, each exhaust stroke complimenting another. i think this is accurate...if not, someone correct me please. thanks
chris
chris
chris
chris
Randyb12
Apr 22, 2004 11:22 AM
