Sponsored by: Innova
stereo wiring
Old Jan 29, 2006 | 09:13 PM
seawolf's Avatar
seawolf
Smile stereo wiring
I'm having a problem with my stereo wiring. When I put my headlights on the lights on the stereo blink for a second. I lose my preset stations when I turn the ignition off...however if I leave the lights on and shut the igntion all the preset stations remain when restarting. Someone mentioned I need a "hot" wire to the stereo and to buy some sort of wire plug???
Anybody have any ideas? Thanks
Old Jan 29, 2006 | 09:36 PM
pfogle's Avatar
pfogle
Ok, I'm going to assume that you cut the wires to install a radio? It sounds like you hooked the ground wire to the dimmer line. It will look like a ground wire until the lights are turned on. That or you've hooked the yellow battery line to the dimmer line. You will need a constant hot on the YELLOW wire, a switched hot for the RED wire, the BLACK wire is a ground, and there will be an ORANGE wire that needs power from the dimmer.
Old Jan 29, 2006 | 09:45 PM
jake00's Avatar
jake00
sounds like you need to hook up the 12 volt "constant on" wire
Old Jan 29, 2006 | 10:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Please get your stereo installed correctly. Many automotive fires are caused by improper installations.
Old Jan 29, 2006 | 11:54 PM
IPACA9's Avatar
IPACA9
I checked your profile and it lists a 1995 F150. Here are your wiring colors for that model.
<table bgcolor="#ffffff" border="1" bordercolor="#d3d3d3" cellpadding="0" cellspacing="0" width="600"> <tbody><tr align="center" height="18"><td class="heading" width="135">Radio 12v</td><td class="small"> lt. green/purple </td><td class="small" align="center" width="135"> + </td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">Radio Ground</td><td class="small"> black and black/lt. green </td><td class="small" align="center" width="135"> - </td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">Radio Ignition</td><td class="small"> yellow/black </td><td class="small" align="center" width="135"> + </td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">Radio Illumination</td><td class="small"> lt. blue/red (dimmer) </td><td class="small" align="center" width="135"> + </td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">LF Speaker +/-</td><td class="small"> orange/lt. grn - lt. blue/wht </td><td class="small" align="center" width="135"> +,-</td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">RF Speaker +/-</td><td class="small"> white/lt. grn - dk. green/org </td><td class="small" align="center" width="135"> +,-</td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">LR Speaker +/-</td><td class="small"> pink/lt. green - tan/yellow </td><td class="small" align="center" width="135"> +,-</td><td class="small" width="130"> radio harness </td></tr> <tr align="center" height="18"><td class="heading" width="135">RR Speaker +/-</td><td class="small"> pink/lt. blue - brown/pink </td><td class="small" align="center" width="135"> +,-</td><td class="small" width="130"> radio harness</td></tr></tbody> </table>
Old Jan 30, 2006 | 07:41 AM
seawolf's Avatar
seawolf
Smile
Thanks for your help.
Bob
Old Jan 30, 2006 | 07:45 AM
seawolf's Avatar
seawolf
Thanks. Do I need to purchase a specific type of wire/plug?
Thanks
Bob
Old Jan 30, 2006 | 07:48 AM
seawolf's Avatar
seawolf
Thanks Jake00 and KCAUTOsound
BOb
Medicpelle
Nov 30, 2016 12:32 PM
ndanielle1968
15
Apr 27, 2015 08:21 AM
dwhawkins89
Apr 11, 2015 10:54 PM
redranger1
May 26, 2013 08:20 PM
S4patrick
Feb 6, 2006 01:13 PM
