transfer case spillage
Old Jan 29, 2006 | 03:08 PM
holocbr's Avatar
holocbr
I was trying to check the fluid level on my '93 F150 4x4 transfer case, I started easing the fill plug out and it started gushing, knocked the plug out of may fingers and I figure I spilled aobut a quart. First I thought I pulled the drain plug, but its the fill plug. (Marked FILL and higher up then the drain plug.) Next I put the rear wheels on stands to see if maybe I had the thing a little down hill and when I ease the fill plug out it still starts seeping. ( I held on tight this time.) I have never heard of there being this much fluid in a transfer case, I have always pulled the fill plug, stuck my finger in and made sure the level is at the bottom of the plug. So if its seeping am I ok? And then how did that much fluid get in there anyway? Its a pretty red color and no signs of leaking.
Any ideas?
Old Jan 29, 2006 | 03:56 PM
tjc transport's Avatar
tjc transport
i ain't rite
if it is an auto trans, maybe the trans is leaking into the transfer case. otherwise, the t-case was overfilled
Old Jan 29, 2006 | 03:57 PM
witdog2020's Avatar
witdog2020
Transmission
The transmission and T/C share the same vent tube, the Transmission will flow over into the T/C. So they need to be divided. seeping is fine gushing is overfilled, and will create friction in the pump, and you get less volume flowing.
Old Jan 29, 2006 | 04:28 PM
holocbr's Avatar
holocbr
After I made the post I did some more searching. I have an auto transmission and I think the transmission fluid is going into the transfer case. The whole reason I was under there today was cause the transmission level was low and I was looking for leaks. I put more in the front, so I bet its going to flow to the rear again.
Next question is how bad is this? Anybody had the seals fixed? How expensive to have a dealer do it? Can the seals be replaced with only removing the transfer case without dropping the transmission? I have pulled old manual trans (etc) before, and if its can be fixed with just pulling the transfer case (and I dont need a press) I'll do it. (And if it can wait a couple of months for decent weather.)
Thanks for the info, any suggestions?
Old Jan 30, 2006 | 07:47 PM
witdog2020's Avatar
witdog2020
one question?
You have 2 seals, 1 on the rear output of the Transmission and 1 on the input of the T/C how do 2 seals fail to get fluid from the tranny into the T/C? it usually don't happen this way because of the large void between them. Check out this thread read #10 this is usually what happens
Good Luck!
https://www.ford-trucks.com/forums/s...d.php?t=423132
Old Feb 2, 2006 | 10:01 AM
holocbr's Avatar
holocbr
Thanks a bunch. I'll check out the breather hoses this weekend.
Thanks for the info, that may have saved me lots of money to have it looked at.
Jason T
Jan 6, 2015 02:04 PM
bowkill
2004 - 2008 F150
Jun 23, 2013 11:35 AM
05victorylly
Mar 21, 2012 04:33 AM
90pioneer
Nov 2, 2011 08:49 AM
AMG-SM
Aug 22, 2011 11:55 AM
