94 Explorer knock sensor location
Old Jan 28, 2006 | 11:23 PM
Bodien460's Avatar
Bodien460
Hi Everyone,
I have a 1994 explorer with about 210K KM on it, and it's starting to ping when it's under light load at highway speeds with the engine at full operating temperature. I have always used premium gas for the milage benefit and tried lower octane fuel as a test to see if the knocking was worse, and it was.
My first attempt to fix the problem was to change out the knock sensor, but the part supplied by the parts store has a 2 wire connector on it, and nothing like that exists on the the motor.
Does anyone know if the 94 models have a knock sensor, and where it might be located??
Thanks.
Bodien460.
Old Jan 29, 2006 | 02:24 AM
Jharger's Avatar
Jharger
I'm wondering what you have in your hand. Early Explorers did not use Knock sensors. If you are now getting the ping - just now - congradulations! Most of us got this about 5-10 years ago.
You need to clean you mass air flow sensor - MAF. Yopu ca find out here http://draco.acs.uci.edu/explorer/
All you need is some carb cleaner and you are good to go for another 30K miles!
The reason why it pings is that the sensor gets dirty and does not see the ture air going by, so it tells the computer to send less gas than it needs. It gets too lean and pings.
rice975.0
Jan 25, 2011 04:21 PM
gpedens
Sep 10, 2009 01:17 AM
fords all the way
May 11, 2008 02:43 PM
explorerguy
1983 - 2012 Ranger & B-Series
Jan 5, 2003 09:01 PM
Hanky
Electrical Systems/Wiring
Feb 10, 2001 12:49 PM
