Compression ##?
Old Jan 28, 2006 | 10:54 PM
ICECREAM MAN's Avatar
ICECREAM MAN
Compression ##?
I HAVE AN '86 F-250 W/ 460. IS AN AVG. COMPRESSION READING OF 115 LBS OK? CAN'T FIND THE INFO IN THE MANUAL.
Old Jan 28, 2006 | 11:17 PM
SuperSnake's Avatar
SuperSnake
Welcome to
Old Jan 28, 2006 | 11:27 PM
T.R.Bauer's Avatar
T.R.Bauer
What are you trying to accomplish with your compression test? Is it burning oil? Do you have a miss? Blue smoke? It sounds pretty typical for an engine with many miles on it. However, your compression is a little on the low side, but that can be caused by a multitude of things that have NOTHING to do with the internal components of the engine. Did you take all the plugs out on the test and are all the cylinders within 10 percent of each other? I need a little more information.....
Old Jan 28, 2006 | 11:30 PM
fordborn's Avatar
fordborn
Thread moved to " 385 Series-6.1/370, 7.0/429, 7.5/460" tech forum. Should be more resources here for the question at hand.
Old Jan 28, 2006 | 11:45 PM
ICECREAM MAN
The Truck Has 119000 Miles On It. So I Wanted To Check It. It Was Up To Temp , Plugs Out,w/7 Comp. Strokes Per Reading. Pressure Built Fast, However I Was Not Sure What Is Acceptable. I Hope To Pull My Camp Trailer With It This Summer! Thanks For The Info
Old Jan 28, 2006 | 11:47 PM
ICECREAM MAN
Oh And Yes I Had I Cyl At 105 The Rest At 110 To 115 Psi
Old Jan 28, 2006 | 11:51 PM
SuperSnake's Avatar
SuperSnake
Did you get my answer in a pm?
Old Jan 29, 2006 | 12:14 AM
T.R.Bauer's Avatar
T.R.Bauer
It is likely fine. It seems a little on the low side, but all cylinders have really close readings to each other and that is good. My 78 had about 90-120 before I rebuilt it. Now it has 145-150, but it has higher compression ratio (10.5:1) than before. Not to mention that it is new. The compression ratio in your engine was 8.4:1 from the factory.
jbulson
Modular V8 (4.6L, 5.4L)
Jul 9, 2016 10:42 AM
galderman
Apr 20, 2013 05:34 AM
whisler
Oct 22, 2010 05:51 PM
TheFonz
Aug 8, 2000 06:34 AM
Nod
Offroad & 4x4
Feb 13, 2000 04:26 AM
