Fuel injection?
Old Jan 28, 2006 | 08:20 PM
edgxrcr's Avatar
edgxrcr
Fuel injection?
Has anyone on here swapped in a fulie or converted there engine to fuel injection? I know there are a few kits out there that are supposed to work pretty good. I havent really heard anything good about pro-jection setups. So if anyone has first hand experience please speak up and let us know what you did. Thanks
Old Jan 28, 2006 | 08:51 PM
iceman7329's Avatar
iceman7329
Maybe you should talk to that guy that is putting a 1992 EFI 4.6 engine in his 77 Short bed.
Wait, thats me. Im gona tell you this now, its not worth it. I just ripped that engine out and sold it.
Old Jan 28, 2006 | 09:23 PM
fp_5's Avatar
fp_5
5.0 or 302 if you prefer EFI swaps have been done countless times. Do a search.
I did one myself years ago, not very difficult if you take neverything you need from a donor.
I had the choice to do it again and went with a carb instead. Personal preference. Do some home work and decide which suits you best as there are advantages to both set ups.
Frank
Old Jan 29, 2006 | 12:21 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check with the engine swap forum.
Old Jan 29, 2006 | 12:44 PM
edgxrcr's Avatar
edgxrcr
I would be more interested in converting a older 460 to injection. I would like to do a 302 seeing how I have a twin turbo setup for one sitting in the garage. But I cant figure a way to do it and still have power steering etc.
Old Jan 29, 2006 | 01:13 PM
Terran's Avatar
Terran
Holly makes a 4bbl system for like 1.5K that replaces your carb, i know JEGS carrys it.
Old Jan 29, 2006 | 01:17 PM
iceman7329's Avatar
iceman7329
Dont get a Holley. There are better products out there for the money.
Old Jan 29, 2006 | 06:20 PM
Terran's Avatar
Terran
Like what mister smarty pants?
Old Jan 29, 2006 | 08:30 PM
lucas restoration's Avatar
lucas restoration
I would go with howell . Had a holley and a howell liked the howell better & if you needed a part to fix a problem on a trip any local parts would have the parts in stock (chebby T.B.) parts make up most of that system. sorry about the bad word.
Old Jan 29, 2006 | 09:25 PM
WrenchHead84's Avatar
WrenchHead84
Whats wrong with a carburetor? There's some advantages to EFI, but I work on cars for a living...and I'd rather have a carburetor.
Now a twin turbo on a 302 would be WILD.
Old Jan 30, 2006 | 09:41 AM
77effie's Avatar
77effie
i am in the middle of a 5.0 H.O. swap ........... nothing to it , i am haveing more trouble plumbing the fuel system than anything, will have to cobble/fab fule lines
feed and return
useing a msd fuel pump that fits my application perfectly
stock ecm,sensors,fuel rail,injectors,
the stock wireing harness can be used just fine but i have opted to use a painless wireing harness for the motor to save time, upgrade to the heavier duty wire and
cleaner install oh yeah they will make an extended length harness so i can mount the
ecm in a better place , includes fuel pump harness and relay
i knew it would be easier to just slap a cam and intake on this motor but every carb i have ever had new or used has started leaking, flooding, sticking ,need adjusting,
dont like the cold , and do not like steep angles ....
i figure the efi will make more torque , start easier in cold , wont mind steep angles
get better mileage!!!! better driveability, be different and wouldnt cost that much more than a new intake and carb ...
but w/ a carb you could still drive around and EMP wont tear up your ecm
ha ha ha.... which if iran keeps it up might be a good feature
