Neutral safety switch problem
Old Jul 25, 2001 | 12:41 PM
naggy's Avatar
naggy
I attempted to change my steering wheel in my 68 f100 automatic. When I put the new wheel on I could'nt start the engine. What is the skinny on this neutral safety switch? Did I cause something to come loose. I spent an hour trying to put every thing back, but still no luck. Thanks
Old Jul 25, 2001 | 01:00 PM
beartracks's Avatar
beartracks
On mine it's a combo switch down at the bottom of the steering column. It detects when you are in nuetral/park to start the engine and reverse for back up lights. Lossen the two screws and move it around till it will start in park then tighten. Check the back up lights too.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jul 25, 2001 | 02:21 PM
dfisher1's Avatar
dfisher1
Traditionally, the neutral safety switch is ontop of the steering column in the cab at the firewall. There is a tube which attaches to the column shifter. On that tube is a clip which protrudes out of the steering column and actuates the neutral safety switch. If the blinker assembly was loosened during your steering wheel job the steering column tube is spring loaded and will push up towards the steering wheel. this in turn causes the clip to recede into the column. If care is not taken when pushing the tube back down into the column the clip will come loose and fall into the steering column. At this point, you will be lucky to retrieve the clip. A magnet on the end of a stick may do the trick. After retrieval, simply reattach the clip to the tube and carefully reinsert the tube into the steering column. Note: you probally noticed its impossible to reattach the blinker assembly. Very loosely attach the two T head bolts to the blinker assembly and place the blinker assembly back in place. Tighten the two nuts until the blinker assembly is held firmly in place. Inspect the neutral safety switch to insure that the clip is protruding from the column and in contact with the neutral safety switch arm. if so, your good to go.
Good Luck
Kingfisher
Old Jul 25, 2001 | 08:57 PM
naggy's Avatar
naggy
Just wanted to say thanks for the helpfull responds. I went and checked the lower steering column and sure enough the switch had been knocked out of place thus causing the no start. So I put the pin back in place and bingo, we got her running again!!! So thanks again for the feedback
Old Jul 25, 2001 | 10:34 PM
jowilker's Avatar
jowilker
Skalywag
Mar 17, 2014 05:06 AM
Dskeet6
Sep 14, 2010 10:29 PM
DonKingKong
Sep 15, 2002 09:26 PM
cpnhgnjnky
Sep 14, 2002 05:52 PM
rick
Feb 23, 2000 10:43 PM
