Help Decyphering Code 96
Old Jan 28, 2006 | 09:46 AM
crawdad's Avatar
crawdad
I pulled the codes on my truck and got a code 96 (Fuel pump secondary circuit failure. The EEC did not sense battery voltage on the Fuel Pump Monitor circuit.) Can someone tell me what this means in plain english? Thanks.
Old Jan 28, 2006 | 01:22 PM
LxMan1's Avatar
LxMan1
Check the fuel pump relay. It is showing that the relay has pulled in, but not passing voltage. It could be faulty.
Old Jan 28, 2006 | 06:47 PM
crawdad's Avatar
crawdad
Thanks a lot. I'll check it out...right after I find it.
Old Jan 28, 2006 | 07:47 PM
Ford_Six's Avatar
Ford_Six
That should be on the firewall, right behind the driver's side fenderwell, in a little plastic box. The fuel relay, if it's the original, will be green.
Old Jan 28, 2006 | 09:45 PM
crawdad's Avatar
crawdad
Thanks, I appreciate that. I didn't have a clue where to start looking.
