airbag watch spring
Old Jan 28, 2006 | 08:30 AM
TN-W124 Diesel's Avatar
TN-W124 Diesel
airbag watch spring
my airbag light has been on for sometime and I took my truck over to the dealership to get a estimate. They want $167 to replace the watch spring behind the steering wheel airbag, is this reasonable? could I do it myself??
Old Jan 28, 2006 | 09:50 AM
RushN350's Avatar
RushN350
It's a fairly easy replacement if you have a steering wheel puller, Once you remove the steering wheel the "Clock" spring is right there clipped onto the colum. Most importantly UNHOOK BOTH BATTERYS and wait a few minutes for all power to drain or you might set off the airbag. Or $167 doesn't sound too far off, I don't know what the ford springs cost but I know the dodges are about $100 just for the part.
Old Jan 28, 2006 | 10:06 AM
Kwikkordead's Avatar
Kwikkordead
Count your blessings, that's a good price for a clock spring. VW want's $600.00+ for one of thier's.
Old Jan 28, 2006 | 08:52 PM
John7894's Avatar
John7894
The spring is around 90-100 depending on the dealer markup. If you have a wheel puller do it yourself. It's very simple. There is a writeup on the site here too I believe.
Old Jan 29, 2006 | 09:08 AM
TN-W124 Diesel
thanks guys!!!, I will let the dealer do this one..I am afraid I would mess it up and it would not go off when needed..
Old Jan 29, 2006 | 10:14 AM
John7894's Avatar
John7894
No way you can mess it up. Don't let the word spring fool you. It's actually an enclosed rotating assembly. It bolts to the column wih 3 screws and has 2-3 connectors on it. It's basically fool proof. No springs will pop out at ya, if that's what you're thinking!
Old Jan 29, 2006 | 03:13 PM
444in.ofgoodness's Avatar
444in.ofgoodness
Actually, you don't even need a steering wheel puller to do it. Disconnect both batteries and wait one minute. Depress the brake pedal for ten seconds to kill any remaining backup power to the RCM (restraint control module). Remove the driver's air bag from the steering wheel. Remove the big nut holding the wheel to the steering shaft, then grasp the wheel at 3 and 9 o'clock. With some serious, even tugging and the occassional slight rock side to side, it should pop off in your hands. The clock spring is mounted right behind it, but you will have to remove the column shroud to access all the screws.
Shark Bait
Feb 25, 2010 07:29 PM
viperbluelx
Sep 10, 2008 07:17 PM
Ford Truck Racer
Apr 16, 2007 07:43 AM
