Dash squeels!?!?!
Old Nov 2, 2013 | 10:34 AM
GuitarJesus's Avatar
GuitarJesus
Dash squeels!?!?!
so my dash squeals and it sounds like there is a damn ferret playing behind it. is this a common problem in the OBS trucks when they get older? And any somewhat simple ways to fix the problem?
on my way out for the day and I don't have time to take the dash apart and look at it. But I'm going to guess that there is a broken mount somewhere?
Old Nov 2, 2013 | 12:23 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Pull the Passenger Side Kick Panel. There's a plastic L shaped tab that mounts the dash to the Cab.
It's a common issue. FoMoCo used to have a repair kit (I.E a $0.35 L Bracket and self tapping screws).
Your local Ace Hardware, Home Depot, etc has the exact same stuff.
Issue solved.
Old Nov 2, 2013 | 01:19 PM
GuitarJesus
Issue solved.
thank you brother! I actually just found the culprit when you responded to my post. I also see that Bronco graveyard sells the fixing kit for $25. I think I'll spend about a buck at Home Depot and call it a day.
Old Nov 2, 2013 | 09:22 PM
SideWinder4.9l
No problem!
Old Nov 2, 2013 | 09:55 PM
nflfreak43's Avatar
nflfreak43
Hmm.. Interesting.. I'll have to check mine.. It's squeaking as well..
Dat lil 302 rattles all kinds of stuff loose.. Lol..
Old Nov 2, 2013 | 11:01 PM
MFJ's Avatar
MFJ
How I did mine.
The hole needs to be enlarged to 1/4", IIRC. The L-bracket needs to get bent. I used the screws that came with the bracket, they run into the plastic fine.
If they loosen in the future, pop rivets will get used.
Finished.
Old Nov 2, 2013 | 11:10 PM
Evan_P's Avatar
Evan_P
I just took a picture of the Ford bracket with me to Home Depot and looked for one that was close to it.
Old Nov 3, 2013 | 09:45 AM
Encho's Avatar
Encho
The Southernmost Mod
Thank god it's an easy fix, It's making me CRAZY!.
Old Nov 3, 2013 | 11:22 AM
joey2fords's Avatar
joey2fords
i had to smile when i read this ... i am still fairly new to fords (4 years owning a ford truck) but the more time i spend reading here the more i see " oh, that's a common problem with these old trucks" ... .
don't get me wrong, my ford earns me a living and i love it , but sometimes ....
anyways, glad yours is an easy fix. if my own dash starts chattering at me i'll know where to look now !
Old Nov 3, 2013 | 01:21 PM
1993_f350_2013's Avatar
1993_f350_2013
I just used a pride of 1 inch aluminum angle and self tapped it into place.
Old Nov 7, 2013 | 07:36 PM
3Sheets's Avatar
3Sheets
weekend
This fix is on agenda for this weekend. Thanks for posting the pics.
19mfn96
25
Mar 31, 2014 10:09 PM
snowdog79
49
Jun 1, 2013 08:03 PM
Jimbocalhoun
1978 - 1996 Big Bronco
Dec 16, 2004 08:31 PM
4poco
Feb 25, 2004 10:51 PM
Doug Nickels
Dec 7, 1999 10:17 AM
