Paint or Undercoating on frame ?
Old Jul 31, 2001 | 12:18 PM
karljay's Avatar
karljay
Don't use an undercoating, use either Por15 or epoxy primer and good paint.
I just finished the back half and now working on the front half and I used a 3hp 22 gal 8.6scfm @ 40 w/ 40# pressure blaster and it barely keeps up but it is working.
The Por15 looks excellent, a nice glossy black and it's made for this type of work.
The undercoating is a good idea for after the paint, but really not needed. I like the idea of rubber undercoating under a painted cab to reduce noise.
Either way, use something specific to rust or frame work for direct contact with the frame, then what ever you want over that.
You might consider boxing part of the frame, just make sure you paint or treat the inside if you can.
Old Jul 31, 2001 | 06:14 PM
frenchie's Avatar
frenchie
If you use rubberized undercoating, be carefull near the exhaust - if it catches fire, it'll be like trying to put out a tire fire!
WallaceSF
18
Sep 10, 2016 10:04 AM
78bigbronco
Aug 26, 2009 10:17 PM
97ExpGuy
May 7, 2009 03:22 PM
badass truck
Paint & Bodywork
Jul 18, 2003 12:25 AM
CheeseandRice
Jul 17, 2003 09:25 PM
