Offroad & 4x4
front driveshaft angles?
Old Jan 30, 2006 | 10:26 AM
  #31
Flareside94's Avatar
Flareside94
39.5's are BIG tires for a D44. You really ought to look for a D60. That WILL be money well spent. Try and talk somebody down on the price for one.
Ideally, for heavy playing you want to stick to 35's or less on a D44, 37's can be gotten away with if you are very careful with how you wheel (IE pick lines vs just throttling over stuff).
Old Jan 30, 2006 | 12:14 PM
  #32
piperig78's Avatar
piperig78
If I can't find a high pinion axle, i have an idea to kick around. Are the carriers the same on the F-250 D44 and the F-150 D44? if they are besides the spring perch could a guy take the tubes off the F-250 axle and put them on the F-150 Carrier and weld a spring perch next to it? I haven't measured anything yet, or looked at my axle, I'm not at home right now but any comments?
Old Jan 30, 2006 | 12:15 PM
  #33
piperig78's Avatar
piperig78
I'm going to some more junk yard this friday, so that is probaby went I'll deside what to do
Old Jan 30, 2006 | 02:41 PM
  #34
DaveBowman's Avatar
DaveBowman
I'll second that
On one of my projects I originally went with a Dana 44 HP, and after a few months I broke a axle joint. Replaced the shaft assembly with another I had laying around, then next trip out it broke again. So I spent $1300 for CTM's and Warn axleshafts and it has solved the axle/U joint breaking problem. For the $1300 I spent on that I could have bought a Dana 60 right from the beginning and still had stronger nuckles and a 5000 pound axle rating.
Old Jan 30, 2006 | 04:59 PM
  #35
piperig78's Avatar
piperig78
I pounded it pretty hard last year getting air and all , but yes a D60 would be nice
DougJ_1997PSD
33
Nov 29, 2015 06:20 PM
bradf350
Apr 12, 2013 08:00 AM
PPrash
Mar 24, 2010 10:15 AM
tecgod13
Nov 17, 2009 07:47 PM
Peter Richards
Jul 4, 2009 11:08 AM
