Bronco II Ford Bronco II
abs
Old Jan 25, 2006 | 09:33 PM
bronocIInoob's Avatar
bronocIInoob
abs
i was reading in a lmc bronco II ranger mag i got for free off there site that sed that on all bronco II's made in 1987 and beyond had the rear abs as standard if this is true then that would mean my 1987 bronco II has that as well this is a problem sence the rear abs light dose not come on at all i am going to look in my manual tonight to see where the abs computer is located and ill try and find it tommoro
is it true ALL had them as standard?
if so, then what could be wrong with mine being that the light doesnt light up?? i was wondering why there was a bulb for it in the cluster when i had to replace all the lights in there. i would LOVE to get that working so i can get somewhat of a break on my insurance rate when i start to drive
Old Jan 26, 2006 | 01:46 PM
bronocIInoob
first time i figured out my own tread lol i looked today and it has the abs computer and the valve, the speed senor wire is cut off when i bough this from the guy he sed he had a newer axle put it in the rear and this tells me alot i looked over the manaul last nite and the speed sensor is in the axle but i didnt look to see if there was one on mine, or if the was a hole for a speed sensor on the axle my best guess is that the guy needed the new axle got it then relized he got one without the speeds sensor port and cut the wire off and removed the abs light bulb from the cluster or he was too lazt to go out and by a new speed sensor but i dont think thats the case at all if it means a new axle what im doing yet ill post back later after i find more out
Old Jan 26, 2006 | 11:25 PM
Desert Dog's Avatar
Desert Dog
Rabs
If you dont have antilock dont worry about it its a pain in the but.
Old Jan 27, 2006 | 08:12 AM
Jker's Avatar
Jker
I got rid of mine. It never worked right any way.
Wiscokid
Bronco II
Jul 4, 2013 10:54 PM
v8xploder
1978 - 1996 Big Bronco
Jun 25, 2011 09:18 PM
aero92
Aerostar
15
Mar 18, 2008 08:21 PM
ROKNZRX
May 18, 2005 10:13 AM
jeff72432
Bronco II
Sep 4, 2002 07:02 PM
