Sponsored by: Auxito
Bumper mods
Old Jan 25, 2006 | 06:34 PM
78bigbronco's Avatar
78bigbronco
Bumper mods
My lower valence was destroyed and I removed it. Here is the truck:
So I have had some ideas and thought of fabricating something myself. Here is what I drew:
I really havent thought of the specifics but I am looking for any advice I can get. I was going to make the main tube from 2.5" pipe and the other pieces either the same or slightly smaller. I was going to fill in the center area with diamond tread to make sort of a skid plate (the verticle pieces dont go straight down, they actualy go back to the front part of the frame/crossmember). I was going to try to build something myself but If I want the main peice to follow the curve of the bumper I might have to go somewheres to have it bent properly. The main peice will sit just below the bumper and ahead of it a few inches, and I was going to mount 2 off road lights on it. Any thoughts?
Old Jan 25, 2006 | 06:38 PM
mat-helm's Avatar
mat-helm
You don't have a trans cooler in there do you? If so you may need a few vent holes.
Old Jan 25, 2006 | 07:43 PM
78bigbronco
Its a 5 speed. But it does have a smaller cooler near the bottom of the radiator, a/c I assume. I dont use a/c except for the hottest of summer days, but I should probably make sure there will be sufficient air flow in my design.
Old Jan 25, 2006 | 08:36 PM
Smaug's Avatar
Smaug
Looks pretty good
Old Jan 25, 2006 | 09:00 PM
preppypyro's Avatar
preppypyro
Actually yeah that does look pretty damn good.
Old Jan 26, 2006 | 08:01 AM
BillyBob69's Avatar
BillyBob69
Bring it up just a bit higher to help improve approach/departure angles then also attach a flat piece of diamond tread so you can mount a winch.
Old Jan 26, 2006 | 10:00 AM
78bigbronco
Whinch? You expecting me to get stuck eh? LOL! I would but I cant afford it... unless I get that 9000# winch from harbor frieght for $300 but for some reason I worry about its strength...
Old Jan 26, 2006 | 10:57 AM
BillyBob69's Avatar
BillyBob69
I would too.
