Sponsored by: Auxito
Power Window Problem
Old Jan 25, 2006 | 03:02 PM
WEFITE4U's Avatar
WEFITE4U
First let me say hello to all and this is my first post. This looks like a very good site and i am hoping to get a lot fo good information.
Now, my problem. I have A 2002 F-150 Supercrew FX4 Lariet that i have owned for a little over a year. My problem is that the drivers side power window wont move. I have been having this problem off and on for a few months. The window would stay up while i pressed the button, but after pressing the button a few times it went down. Now, the window is open about one inch and wont go back up. All of the others windows work fine. When i press the button to open the window i can hear a click coming from the lower left side of the dash behind the fuse panel. Is this a standard Ford problem, and if so, how do i fix it? I am pretty knowledgeable when it comes to electronics and mechanics so if someone can just point me in the right direction it would be appreciated.
Old Jan 25, 2006 | 03:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 26, 2006 | 12:23 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
I'd have to guess that you have a bad power window motor.
If you remove the door trim panel you can check for power and ground at the motor. It reverses polarity to move the window in the other direction. You can use a test light to check for power and ground at the motor. Put the test light's ground in one terminal of the connector and the probe in the other. The light should light when you press the switch in either direction.
You might want to tap the motor lightly and see if it goes again. Sometimes they will just have a bad spot.
Old Jan 26, 2006 | 08:38 AM
Johns9163's Avatar
Johns9163
If the window has seen alot of use in it's life....the bushings in the motor will get worn and the motor will bind. Typical issue. If you remove the door panel and give the motor a gentle tap, well, maybe a little more then gentle.....it will start to work again but, only temporarily. It gets bound up. Replace the motor. Not a big job to do.
My father-in-law had a Ford truck that had a bad motor in it. He kept a piece of 2X4 in his truck and would litterally smack the door panel with it when it got stuck. It went back to working but his door panel was in pretty bad shape after a few years of doing this!!! Guess he was just too lazy to fix it correctly.....
Old Jan 26, 2006 | 10:30 AM
WEFITE4U's Avatar
WEFITE4U
I kind of figured it was the motor going bad. When i got home last night i just hit the door where i thought the motor shoudl be and it worked, but now it is not working again. Where is a good place to go to get a NEW motor? I dont want to go to the dealer in town because i am very unhappy with them. I really appreciate the help.
Old Jan 26, 2006 | 11:08 AM
WEFITE4U's Avatar
WEFITE4U
Never mind, I can get one from Autozone for $84. Thanks for the help.
