What oil filter do you prefer?
Old Jan 25, 2006 | 02:09 PM
blhfla's Avatar
blhfla
Not to start a brand war or anything, but what oil filter do you prefer? Please include the model # (in case I decide to take your advice). This will be my rig's first oil change by me (110k miles) and I plan to change with non-synthetic every 5000 (filter every 2500).
Old Jan 25, 2006 | 02:24 PM
PSNut's Avatar
PSNut
www.fleetfilter.com carries excellent Wix filters cheap.
Nut
Old Jan 25, 2006 | 03:13 PM
blhfla's Avatar
blhfla
Would that be the 51734 or 51734XE (synth media)?
Old Jan 25, 2006 | 03:23 PM
clintbonnie's Avatar
clintbonnie
I like FleetGuard LF 3974 (getting them from "Geno's, one of our sponors) Also suggest you get a "bypass filter" from "OilGuard" if you are going to stretch your changes to 5000 miles using non synthetic..
Old Jan 25, 2006 | 03:26 PM
ford390gashog's Avatar
ford390gashog
wix makes a good one. no need to change the fitler every 2500 miles. the oil and filter are good for 5,000 easy plenty of uoa's support they can go 7500 miles on the same oil and filter and still return great results.
Old Jan 25, 2006 | 06:34 PM
SpringerPop's Avatar
SpringerPop
Baldwin B7039 full-flow. B164 bypass.
I completely agree with gashog above.
Pop
Old Jan 25, 2006 | 07:42 PM
Ford Truck Racer's Avatar
Ford Truck Racer
Have not used the on a diesel yet but the K&N filter filters down to 10 micron, smaller than most which are 30 micron.
Old Jan 25, 2006 | 07:50 PM
PSNut's Avatar
PSNut
I'm thinking the smaller particles a full flow filters the quicker it gets pluged up.
Good reason for bypass filters.
Nut
Old Jan 25, 2006 | 08:29 PM
ford390gashog
the stock filter has a nominal micron rating of 20. the wix replacement is 19 and flows 30 GPM.
Old Jan 25, 2006 | 08:38 PM
ford390gashog
the K&N shows 20 GPM and a nominal rating of 14.
Old Jan 25, 2006 | 09:50 PM
f350xlt460's Avatar
f350xlt460
i like my wix filters on the truck, seems that the oil stays cleaner longer then fram.
Old Jan 25, 2006 | 09:56 PM
1984_355w's Avatar
1984_355w
If it's a ford I run a Motorcraft
Old Jan 25, 2006 | 10:04 PM
Muktown's Avatar
Muktown
i use the motorcraft because i can get them at wal- mart for under 10 bucks
Old Jan 25, 2006 | 11:36 PM
jtharvey's Avatar
jtharvey
I use the Wix that I pick up at O'reilly's. I doubt it's the synthetic media. I do plan on ordering up a few from fleetfilter before my next oil change though, to save some money.
Old Jan 25, 2006 | 11:55 PM
dagren99's Avatar
dagren99
Oil Filters
I use Either the Ford FL-1995 or the NAPA Gold 1734.
Usually the NAPA's are a buck or two cheaper than I can get the Ford filters.
I do like the 1995's gasket better than the 1734's. (Ford's is tapered - napa's is flat)
DG
