Aerostar Ford Aerostar
Help! Dropped socket in engine
Old Jan 24, 2006 | 07:41 PM
imabwithanitch's Avatar
imabwithanitch
Exclamation Help! Dropped socket in engine
So now I feel like an idiot. While putting the top half of our 4L back together, the socket fell into the manifold. Tried using a magnetic grabber but couldn't find it, so tore down to the rockers. Still can't find it. Anybody have any ideas that don't involve tearing the whole thing apart?
Old Jan 24, 2006 | 07:55 PM
b2trausch's Avatar
b2trausch
If you can find a mechanic that has a borescope, you should be able to locate it. Some borescopes have that ability to retrieve items.
Old Jan 24, 2006 | 08:19 PM
VanGo's Avatar
VanGo
Are you sure it's not in your toolbox?
When you say tore down to the rockers, do you mean you removed the intake? If it went down the intake runners than it can only head for a cylinder with an open valve right? The rockers would tell you which cylinders are open.
How big was the socket? Size would limit the possibilties.
Old Jan 24, 2006 | 08:34 PM
T18skyguy's Avatar
T18skyguy
Just thinking out load, but if it's small enough to pass a valve then maybe you could retrieve it through a spark plug hole. Pull all the plugs and gently rotate the engine till it obstructs-then the socket should be at top dead center close to the plug hole. Then maybe a magnet might work. How small a socket would pass a valve?
Old Jan 24, 2006 | 08:53 PM
imabwithanitch
The #$*## socket is a 7/32, small enough maybe to pass a valve, and no, it's not in the toolbox, that would be far too easy. I watched it drop down the intake runner. What is a borescope?
Old Jan 24, 2006 | 09:06 PM
Mormakil's Avatar
Mormakil
Bang that manifold around and try to dislodge the socket, it might be wedged in there somewhere. Don't beat it up, just try to shake the socket loose.
T
Old Jan 24, 2006 | 09:36 PM
aerovan's Avatar
aerovan
borescope is like a fiber optic scope that snakes into small areas, you will then view thru the scope toward the end of the fiber optic snake.
Old Jan 24, 2006 | 09:41 PM
cbr900's Avatar
cbr900
I don't think a 7/32 socket would pass the valve seat, (why a 7/32 there all metric in there). It must be in the intake maifold some place, have you tried on of those thin 4 prong grabbers they expand when you push the end and you can get them from sears or any well equiped auto store, plus there bendy so you can get them around cornners I have used mine many times to retrieve lost nuts and bolts. One other thing though if you have turned the engine since you lost it may have got jammed between the valve and seat, but then you would have a tight valve spring were you should not.
96_4wdr's Avatar
96_4wdr
a 1/4" inch drive socket is over 3/8" in outside diameter on drive end....never pass intake valve...still at the bottom of the head passage runner against the intake valve...are u sure which hole?
use a pickup magnet on a flexible shaft and search until it comes out....will take the head right off a valve
Old Jan 27, 2006 | 10:10 AM
imabwithanitch
Smile
Finally go it out! It was wedged pretty well in the intake valve, but what a pain to get it out, spent many frustrating hours with flexi magnets, grabbers, fingers, etc. Now to put it back together. Thanks for all the advice.
Old Jan 27, 2006 | 02:24 PM
93nighthawk's Avatar
93nighthawk
Glad to hear you got it out without blowing up your engine.
Thankfully I have never done that (banging very hard on wood.)
Old Jan 27, 2006 | 03:48 PM
Nappers's Avatar
Nappers
glad you got it out, I had a teacher in high school drop a small 3/8 in wrench in the intake before putting the carb on his Chevy 350, the valve snapped the wrench in half and it bounced around different cylinders until he shut it down. beat up the pistons pretty good, bent the valve, put a new valve in and called it a day. He said no major scoring on the cylinder walls. He was lucky. He sold the truck some time later. LOL.
Aaron
Old Jan 30, 2006 | 09:37 AM
imabwithanitch
It's one of those things you hear of but only happens to other people. Now that it's over i can laugh, but at the time I though maybe alot of swearing & threats would convince the engine to cough it up lol
Old Jan 30, 2006 | 09:42 AM
IBeam's Avatar
IBeam
Yet another use for Duct Tape. Cover the holes. Not that it ever happened to me (digs toe in the dirt)
Rusty_S
Garage & Workshop
Jul 12, 2017 10:20 PM
Eli1644
Feb 2, 2017 05:41 PM
buck_
1978 - 1996 Big Bronco
24
May 10, 2016 12:27 PM
ac700wildcat
Feb 19, 2011 11:16 AM
EXv10
Feb 11, 2011 04:59 PM
