Icm socket size?
Old Feb 16, 2011 | 05:28 PM
ac700wildcat's Avatar
ac700wildcat
Icm socket size?
1994 f150 302 remote icm
So here I am trying to change my icm and wouldn't you know I can't get the two bolts out to swap them. It just a normal hex head socket and none of my sockets work on it. I found out you need a special tool, so I went and bought one and that doesn't grab onto the bolt head either. So what size socket am I looking for?
Old Feb 16, 2011 | 05:47 PM
Slip ford man's Avatar
Slip ford man
5.5mm...1/4 drive, long reach socket, got mine at AutoZone
Old Feb 16, 2011 | 06:24 PM
LCAM-01XA's Avatar
LCAM-01XA
ICM = TFI module? Then yup, what the gent above said.
Old Feb 16, 2011 | 06:54 PM
ac700wildcat
well i have to run and grab some vacuum line neways, so I'll grab a 5.5mm deep well too and see what happens.
Old Feb 16, 2011 | 07:30 PM
cjben's Avatar
cjben
if they don't have the right size socket,most parts stores have a special tool you can buy for a few bucks, does the job very well. Look for "ford tfi" tool or something similar IIRC.
Old Feb 16, 2011 | 08:36 PM
rla2005's Avatar
rla2005
Nice photo and description from Ryan here: Ford Fuel Injection » EFI Tools
Old Feb 17, 2011 | 12:32 AM
LCAM-01XA's Avatar
LCAM-01XA
The "Ford TFI" tool is preferable anyways, cause it's pretty thin-walled and so fits well in the holes in the TFI, whereas some sockets have slightly thicker walls and so may not fit.
Old Feb 19, 2011 | 11:16 AM
LADNAR's Avatar
LADNAR
Ive got the plastic handled one but I broke off the plastic and used a wrench on it do to clearance on one vehichle or another I had or still have. Not much money and you know what its for.
Mudsport96
May 24, 2017 09:25 AM
drwecki
Mar 2, 2017 06:44 PM
jeepdad287
Feb 6, 2017 07:35 PM
KC92F150
1978 - 1996 Big Bronco
Mar 25, 2009 10:06 AM
