351M - 390 swap
Old Aug 9, 2001 | 06:22 AM
Irondale90's Avatar
Irondale90
351M - 390 swap
[font size="1" color="#FF0000"]LAST EDITED ON 09-Aug-01 AT 07:41 AM (EST)[/font][p]So are the guts from a C-6 off of a 390 block, interchangable with the C-6 guts off of a 351M block? The C-6 I have that was bolted to the 390 spent the last 6 years in the dirt without any protection. It has to be rebuilt and the C-6 in my truck now works great. I got the 390 and the C-6 for free so you cant beat that deal.
Old Aug 11, 2001 | 08:30 AM
dinosaurfan's Avatar
dinosaurfan
351M - 390 swap
Yes, you can swap the 'guts' from one case to the other. You will have to take things apart anyway so the shorter output shaft can go in the C6 that is behind the 390. Your truck will be newer than you engine, but the 73-76 trucks, which came from the factory with a 360, are very similar and should have the parts you need, if any. DF
Old Aug 11, 2001 | 10:09 AM
otto's Avatar
otto
351M - 390 swap
