1984 t0 93
Old Jan 24, 2006 | 02:27 PM
s8whiskey's Avatar
s8whiskey
1984 t0 93
I have a 93 F150 5.8L 4X4 and Im buying a 84 f250 4X2 5.8L and It has a sterling under it and I was wondering if I can do a swap between them. Im buying the F250 for the engine and tranny (Im getting it for 200). The engine needs a disributor and thats it. It has like 71K on it. Im getting it from my friend so I know what happened to it. Just can I change that rear for my 8.8?
Old Jan 24, 2006 | 02:29 PM
tjc transport's Avatar
tjc transport
i ain't rite
if the gear ratio is the same, it should be a bolt in. if the ratio is different, you will have to regear it before you can use 4X4, otherwise you will need to replace allot more than just gears.
Old Jan 24, 2006 | 02:34 PM
s8whiskey's Avatar
s8whiskey
What about the VSS?
Old Jan 24, 2006 | 03:06 PM
andym's Avatar
andym
VSS is a big problem. Your speedo, tranny, and ABS need it to function correctly. Besides - you'd have to carry two spares.
Since you're swapping the tranny, though, the biggest problem would be getting by without a speedometer.
Old Jan 24, 2006 | 05:57 PM
tjc transport
i ain't rite
or swap in a speedo head from an earlier truck that used a cable
Old Jan 24, 2006 | 10:58 PM
s8whiskey's Avatar
s8whiskey
I want to keep the 93 tanny the same just want to swap the rear end. Im going to slap the engine tranny into a 62 Fairlane. Can I drill and tap the rear end for a VSS
Old Jan 25, 2006 | 11:21 AM
quicklook2's Avatar
quicklook2
it still needs ring on gear.
Old Jan 25, 2006 | 11:23 AM
s8whiskey's Avatar
s8whiskey
Ive changed many gears but whats in the rear end for the VSS to operate can I pull it out and install it.
Old Jan 25, 2006 | 11:25 AM
andym's Avatar
andym
No, it won't work. If I'm not mistaken, the carrier is different for trucks that have a tone ring. I don't know if the cases are the same or not.
In any case, you can't swap the rear axle. It just won't work.
Old Jan 25, 2006 | 11:28 AM
s8whiskey's Avatar
s8whiskey
Those B******s. haha oki doki. So Ill just have to look for a different tranny and run after market speedo. Just more scavengin.
Old Jan 25, 2006 | 11:29 AM
andym's Avatar
andym
What are you going to do about the front? Are you going to convert it to 2wd, buy an 8-lug front axle for it, hope you don't get a flat, or carry two spares?
Old Jan 25, 2006 | 11:35 AM
s8whiskey's Avatar
s8whiskey
Im looking for a solid front just gotta find it. I got this rear just thought I would put it in and wait for the solid. but Ill need to get the tranny and stuff first. It would be aweosme to find a 4X4 of the truck I just bought and put the fairlane body on the truck frame
bsquash
Sep 23, 2013 02:46 AM
redmun
Aug 22, 2013 11:57 AM
hatchet
Aug 3, 2008 12:33 PM
93truck
Jun 15, 2006 09:53 PM
