Fuel gauge wrong reading
Old Jan 24, 2006 | 01:52 PM
1Knight's Avatar
1Knight
03 f-350 6.0 diesel......
31k miles and all of a sudden I stop for fuel, fill up and when I restart, the gauge goes to 1/4 tank. My information overhead reads out I have "503 miles" to empty.
Old Jan 24, 2006 | 05:57 PM
Franklin2's Avatar
Franklin2
If you want to test the guage and the wiring, take the plug off the tank and look for a yellow/lightblue wire. Turn the key to run without starting the truck, and the guage should go to full with the yellow/lightblue unplugged from the tank. Then take a short piece of wire and jamb it up in the connector so it makes contact with the yellow/blue wire. Then take the other end of the short piece of wire and ground it to a clean place on the frame. The fuel guage should swing from full to empty.
If all the above passes, then that means your fuel guage and wiring to the rear are good, and there is something wrong with the sending unit in the tank. There may be a hole in the float causing it to sink.
Old Jan 26, 2006 | 05:04 PM
1Knight's Avatar
1Knight
It went from 1/4 to full (very slowly) in about 25 minutes. ???
Old Jan 26, 2006 | 07:23 PM
oojbearoo's Avatar
oojbearoo
your float may be sticking ...or possibly the sensor is on its way out
erniek70
Oct 18, 2016 01:07 PM
BigDan1
18
Mar 26, 2016 08:28 AM
Stage III
Jan 18, 2012 05:09 PM
navigatorstang
May 15, 2011 03:08 PM
Rbuller24
15
Jun 11, 2003 06:29 PM
