CEL Bulb
Here is a photo of it.
I had to do this to a pontiac grand prix I bought for my daughter. The headlight pod illumination light was out, and when I got it tore apart, found it was a very small bulb with leads coming out like your picture, and this fit into a long slender plastic piece with the leads bent at the bottom. Of course only the dealer had it, so I found the smallest bulb I could at the autoparts store, soldered the leads to it, and threaded it into the plastic piece. Works better than I ever thought it would. The brightness is even the same.
I took a dial illumination bulb for a 1980 Ford Radio and soldered the wires from the old bulb together with the wires from the new bulb. It was a Sylvania #37 Code 334170 bulb.
Works great.
Bill K
