need help fast
Old Jan 24, 2006 | 12:22 PM
7FORD2's Avatar
7FORD2
Question need help fast
ok fellas i need help installing an aftermarket oil pressure guage. i know how it all hooks up but i do not how to get the original sending unit off to hook up the guage. this is what i need help with. also this is on a 69 f250 4x4 with a 390 in it. thanks
Dustin
Old Jan 24, 2006 | 12:36 PM
billemc's Avatar
billemc
The sending unit should just unscrew, a 12 point wrench or deep socket should get it. There should be fittings and adapters with the new gauge. If the sending unit is origional you might have to get mean with a pair of vice grips or something. Gook luck, Billemc
Old Jan 24, 2006 | 12:45 PM
bertha66's Avatar
bertha66
The old one should turn out, you my need a socket or wrench, what ever will fit it.
Old Jan 24, 2006 | 12:47 PM
1975Ford's Avatar
1975Ford
Should have a hexagon type of metal at the base of the original oil sender unit which a wrench can attach to unscrew the unit, the oil sending unit is attached above the oil filter adapter unit. Make sure to use teflon tape on threads, when installing the new oil adapter unit.
Old Jan 24, 2006 | 02:06 PM
7FORD2's Avatar
7FORD2
well fellas i tried everything to get it off and it aint comin off so now wat cause the stock pressure gauge dont work. and how am i to know wat the hell pressure? so just lemme know what else to try. thanks
Dustin
Old Jan 24, 2006 | 02:12 PM
amish77's Avatar
amish77
Try some good penetrating lube, and if that dosen't work, get some mechanix gloves, let the truck get to temperature, and try it then. you may burn the crap out of your hands, but it'll expand the hole, maybe enough to pull the sending unit.
Old Jan 24, 2006 | 02:18 PM
7FORD2's Avatar
7FORD2
so after i pull off the nut and washers it will pull right off or does it screw off?
1975Ford's Avatar
1975Ford
Put some penetating oil like amish77 mentioned. The place the wrench on unit, and hit the wrench at the end with a solid hammer, in the counter clock wise direction. This might jar it loose.
Old Jan 24, 2006 | 02:27 PM
IBeam's Avatar
IBeam
Nut and Washers ? Forgive me if I am wrong, but there should not be any nut and washers. Are you working on the right thing. The Oil Sensor should have a metal base with a plastic top, and small brass stud coming out the top, and have a single wire connector that pushes over this stud. I forget the size, but they make a special socket with 12 points just for pulling these out. It is around a 1 inch socket. It should be a simple process of unscrewing it with the socket. I have never seen one stuck and not move. Off the top of my head, the only thing I can think of is your trying to remove a block heater that goes in a Freeze Plug Hole.
I have seen some old sensors that had a 5/16 nut and washer on them. If this is the case, then under the bell part of the sensor next to the block, they have a square part that a 9/16 wrench will slip over. Sometimes they are hard to get a wrench on, but it can be done. Turn it in a counter clockwise rotation and un screw it.
Old Jan 24, 2006 | 02:29 PM
7FORD2's Avatar
7FORD2
at the base of the original sending unit there aint a hexagonal piece of metal to put a wrench on so now what?
Old Jan 24, 2006 | 02:51 PM
7FORD2's Avatar
7FORD2
i am working on the right thing. the nut and washers are on the brass stud. then the little boot slips on to the stud. so i took those off and tried unscrewing the bell part and it turns but just keeps turning and not coming off. so now what?
Old Jan 24, 2006 | 03:31 PM
qman's Avatar
qman
Can you post a pic? You've got us all scratching our heads.
Old Jan 24, 2006 | 03:33 PM
7FORD2's Avatar
7FORD2
my comp is all screwy and dont let me upload or post pics plust my friend has my cam
Old Jan 24, 2006 | 04:35 PM
MR_J_DAHMER's Avatar
MR_J_DAHMER
Dustin
It's hard to see, but under the bell shaped top of the oil sending unit, and above the threaded part is a 9/16 hex, get out your open ended 9/16 wrench and turn ccw. Plan B, take out a big hammer, smack it till it breaks off the sender and stem. Remove the end of the broken stem with an easy out. Install gauge fittings and line. DO NOT USE PLASTIC! Go to your local hardware or parts store and get copper tubing...DAHMER
Old Jan 24, 2006 | 05:14 PM
1975Ford's Avatar
1975Ford
Clean and scrape at the base of the oil sending unit with a thin small screw driver, you should notice the 9/16" hex nut at the base of the oil sending unit. Sometimes it hard to see because of the power steering pump and fuel pump location.
