busted head bolt....ideas please...
Old Jan 23, 2006 | 09:29 PM
MontanaFord's Avatar
MontanaFord
the truck is ain 83 f-250 300-6 4 spd....i have a head bolt that sheared off at an angle, basically flush with the block....have so far busted one EZ OUT off in the bolt....any other good ideas???
thanks....
Old Jan 23, 2006 | 09:37 PM
big hoss 29's Avatar
big hoss 29
Hey montanaford, haven't heard from you in awhile!
Old Jan 23, 2006 | 09:53 PM
Evil1's Avatar
Evil1
Could try welding another bolt to the busted bolt and try to extract it that way..the heat from welding on the other bolt can tend to help with breaking it free as well..Good luck
Old Jan 23, 2006 | 11:14 PM
fordborn's Avatar
fordborn
Thread moved to " Inline Six, 200, 250, 4.9/300" tech forum. Should find more resources here for your question.
Old Jan 23, 2006 | 11:29 PM
oldhalftons's Avatar
oldhalftons
Strip it down to the bare block, put it on an engine stand and melt the EZ-out and bolt out of the block with an O/A torch. the steel bolt and extractor will melt long before the cast iron threads will be damaged. you'll still need to chase them with a tap though.
Old Jan 24, 2006 | 10:16 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy
I usually try and weld on, but when it's flush like that is hard, but if you use a bolt that is smaller, just weld around where the treads are and you should be alrite b/c the weld doesn't like to bond to cast if you get off a little, then try, another thing I've done is just take the wire feed and built up a nube then weld a nut on, good luck, that sucks when that happens, but we've all about been there and done that, lol
Old Jan 24, 2006 | 06:29 PM
MontanaFord
thanks for the ideas, guys...i'll see about givin a couple of them a shot...letcha'll know how things go...
MontanaFord
pholmes350
Dec 30, 2013 08:06 PM
custom cabby
Sep 1, 2010 01:18 PM
Dutch123
1978 - 1996 Big Bronco
Aug 1, 2009 06:16 PM
paintslinga2010
Oct 27, 2008 07:32 PM
MHull
Aerostar
18
Mar 17, 2006 07:45 PM
