Changing the shift points?
Old Jan 22, 2006 | 07:42 PM
Tjax's Avatar
Tjax
Can't remember what that little ******* is called... the little bulb on a C6 trans where the vac line goes in? Is it true that I can adjust when it shifts by turning that little screw? My trans shifts sooner than I'd like and that'd be sweet.
Old Jan 23, 2006 | 06:25 AM
stuart1's Avatar
stuart1
Little bulb
Is called a vacuum modulator.
The small screw inside can be turned in.
Which will raise the shift points a few kilometers / miles per hour.
Behind the valve is a short pin that can be lengthened which will have a greater affect.
Old Jan 23, 2006 | 09:32 AM
Tjax's Avatar
Tjax
Thank you.
Old Jan 23, 2006 | 08:30 PM
53fatfndr's Avatar
53fatfndr
As to the small internal screw, turn it in (clockwise), to raise the RPM shift points. Turn it out (counterclockwise) to lower the RPM shift points.
801anderson
May 24, 2023 02:13 PM
C&d roadside
3.0L V6
Sep 22, 2016 09:30 PM
RIKIL
27
Jun 29, 2016 04:44 PM
AteThePrincess
1983 - 2012 Ranger & B-Series
Feb 21, 2016 04:45 PM
Bellamy
1978 - 1996 Big Bronco
Oct 23, 2010 08:22 PM
