1978 - 1996 Big Bronco
Trans problem??????
Old Oct 21, 2010 | 04:07 PM
Bellamy's Avatar
Bellamy
Trans problem??????
My 89 trans was running pretty well (a little hard on the shifts at times) and now I can do reverse just fine, first fine as well, but in (D) or D after it makes a smooth change from 1st to 2nd and 2nd seems fine but around 35mph the tranny basicly lets go. I can still accelerate a little but the engine revs almost like it is free. Any ideas where the problem lies? It's an AOD btw.
Old Oct 21, 2010 | 04:34 PM
AbandonedBronco's Avatar
AbandonedBronco
Have you checked the fluid and checked/cleaned/replaced the transmission fluid filter?
Old Oct 21, 2010 | 04:40 PM
Encho's Avatar
Encho
The Southernmost Mod
Wich tranny do you have? if it's an electronic one (E4OD) the solenoid pack is the most possible culprit.
Old Oct 21, 2010 | 04:43 PM
AbandonedBronco
Originally Posted by Bellamy
It's an AOD btw.
Does the AOD have a solenoid pack as well?
Old Oct 21, 2010 | 05:15 PM
Encho's Avatar
Encho
I don't think so, it could be a stuck valve then.
Old Oct 22, 2010 | 09:26 AM
Bellamy's Avatar
Bellamy
Oddly enough the fluid level was higher then it should have been. I have since then drained a little out to put it at the correct level. That didn't seem to make any difference.
Old Oct 22, 2010 | 08:12 PM
greystreak92's Avatar
greystreak92
The AOD uses a throttle valve (TV) cable to manage shift points. This cable links, as you would expect given its name, the throttle valve position with the shift control in the AOD. There is a very specific procedure to adjust it but I would be willing to bet (based on the symptoms you described) it needs the TV cable adjusted properly. A fluid and filter replacement wouldn't hurt either.
Old Oct 23, 2010 | 06:27 PM
Bellamy's Avatar
Bellamy
How would I go about adjusting that? Any links or advice? As for the filter change I already got a new filter to do that, I figured it couldn't hurt.
Old Oct 23, 2010 | 08:22 PM
greystreak92
I haven't done it but I know there are folks here who have/know how. Someone should chime in soon.
