Edlebrock wierdness
Old Jan 22, 2006 | 11:00 AM
Terran's Avatar
Terran
Edlebrock wierdness
What's up with this, my truck has an Edlebrock Performer intake and Carb when i drive somtiems the rpm will stay high when i take my foot of the gas in neutral, but somtimes it just goes back down to idle, any ideas? It seems to happen randomly.
Old Jan 22, 2006 | 11:29 AM
Dave Severson's Avatar
Dave Severson
You might want to check your throttle linkage/cable for binding and also make sure the throttle return spring is installed and of sufficient strength. Depending on what air cleaner you are using, there's a chance the top of the throttle are could be hitting the bottom of the air cleaner????
Old Jan 22, 2006 | 01:16 PM
Terran's Avatar
Terran
I'm using the stock one and it seems strong enough, although i'll consider using a stronger one for it though.
Old Jan 22, 2006 | 02:24 PM
User 71024's Avatar
User 71024
if it has an automatic choke it could be a sticky high idle cam that doesn't always return.
Old Jan 22, 2006 | 09:17 PM
Terran's Avatar
Terran
It is an automatic choke, but i'm not sure what you mean about the cam, it's the stock one that came with the 302 (Although that will change soon)
Old Jan 22, 2006 | 11:54 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
The above reply was about the nylon cam behind the choke thermo coil, if the cam sticks it will not fall down by gravity and the steps will contact the fast idle adjustment screw. This will hold a fast idle on a warm engine. Make sure the whole choke assembly is free and not sticking, if not spray with a carb cleaner. Check the choke plate to see if it's fully open when the motors warmed up.
.....=o&o>.....
Old Jan 24, 2006 | 10:21 PM
Terran's Avatar
Terran
OK, so it seems like it only does it when i move it around at low rpm, if i'm at high rpm and take my foot off the gas it goes to a normal idle, but if i'm just going around slow it'll stick in faster light sombody slowly put their foot on the gas to that point.
Old Jan 26, 2006 | 04:58 PM
Terran's Avatar
Terran
Since my sparks are also pitch black i think my carb could use a little tuning.
Old Jan 28, 2006 | 01:29 PM
LxMan1's Avatar
LxMan1
Sounds like the choke isn't opening fully.
Old Feb 1, 2006 | 10:08 PM
Terran's Avatar
Terran
It's hard to tell here in the freezing winters of the northeast, but when i stab the throttle when it does it it stops.
okie72
18
Jan 18, 2014 07:28 PM
71_4x4_390
49
Jan 5, 2010 10:28 PM
phildjsa
2004 - 2008 F150
Dec 14, 2009 06:23 PM
1972fordf-100
Dec 18, 2008 12:19 AM
palmrose2
Sep 22, 2004 09:31 PM
