I installed a edlebrock intake and a motorcraft 4160 4 barrel carb on my 1978 400 modified. My problem is there is nowhere on the intake to hook up the tube for the hot air choke. When you give it some gas it sets the choke and the motor revs up.
on a 360FE I had I installed a hot air pickup off the header tube. Used 1/4 copper line to the carb. Basicly a metal shield hose clamped to the header then the 1/4" line went inside.
The carb is made by Holley. Are all Holley electric chokes the same. How do I find out which choke to order? Also if I put an electric choke on do I block off where the hot air tube goes I can feel vacuum there?
I ordered an electric choke and installed it. The choke works good but when the motor warms up and the choke kicks off the carb runs very rich at idle. A lot of smoke at idle and strong fuel smell. Any idea what my problem is?
You're running too rich. Use the idle mixture screws on the carb to tune the idle mixture (hence the screw's names). Theyre the 2screws on the front of the carb. To properly tune the carb, go get a vacuum gauge (assuming you don't already have one) and hook it up to manifold vacuum. Then tighten down both screws EQUALLY until they either bottom out or the engine stops running. Then back them out EQUALLY and watch you vacuum gaige. Back the screws out until you see the highest amount of vacuum on the gauge, then turn the screws in about an 1/8th of a turn.
My carb doesn't have idle mixture screws in the front of the carb like most. The instructions for the carb say The mixture screws are pre-set at the factory and require no adjustment. Maybe because it is a Motorcraft carb made by Holley it is an odd duck. The only mixture adjustment I can find on the carb is two white plastic screws one on each side of the front fuel bowl. I have turned them both ways and it made no change to the carb running rich. There are no other mixture screws that I can find on the carb.
I took the plastic caps off and the two screws makes no change in the rich condition they can be all the way in or all the way out and it still smokes black at idle and the vacum gauge reads 17-18 if the two screws are in or out.
Something definitely doesnt sound right at all. How new is this carb? How many rpms do you have at idle? Sounds like youre just dumping gas down the engine...aka flooding the carb.
I agree the carb is new the guy had it for a few years but it sat on the shelf and he never used it. I have the carb set at 650-700rpm for idle if you rev the motor it pours black smoke and you let off and it almost will die but it will stumble and go back to idle. Also if I screw both screws in the doesn't die.
Im thinking that that carb hands down needs a rebuild. Even just hearing that it sat unused for a few years is reason enough to rebuild it. At this point your floats may be stuck, accelerator pump may be bad, etc.
