9 inch rear ends
Old Aug 21, 2001 | 09:05 AM
Thudpucker's Avatar
Thudpucker
9 inch rear ends
Old Aug 22, 2001 | 03:47 AM
BFor321's Avatar
BFor321
9 inch rear ends
.....I'd say first, figure out what you have ratio wise. Do you have an open diff or a limited slip one? I'd guess if you have a 9 inch its probably open. I have a F100 w/ a Dana rear thats limited slip and two 9" rears that are open. To figure that, block front wheels on level ground to prevent rolling, and jack up both rear wheels off the ground. Now w/ truck in neutral and front tires chocked, turn one of the rear wheels.... Does the other one turn with it in the same direction? If so you have a limited slip. Does the other wheel not turn or even maybe turn in reverse? Then you have open diff. Now... if you have limited slip, the calculation is easier. Make a mark on your tire at say 12:00 and make a mark or visualize one on the driveline perhaps by the U joint. Rotate the tire once.... how many times did the driveline rotate for that one turn of the tire? Two of my truck have 3.50:1 rears that means that for one turn of the tire, the driveline went around 3 1/2 times. I have another truck that I've swapped a 3:25 into, that is one turn of the tire, 3 1/4 turns of the driveline. Now with the open differential, I believe you have to imobolize one of the tires by lowering it to the ground and doubleing the # of driveline turns. Since this is rough measuring I think it helps to turn the wheel more times to average out the results..... What I mean is for example.... a 3:50 rear ratio, for one turn of the wheel the driveline would turn 1 3/4 (half of 3 1/2) or for 2 turns of the wheel, 3 1/2 turns of the driveline, or 3 turns of wheel 5 1/4 turns.
BBT
open diff gear ratio calc above is wrong.
The best way to calc. gear rayio is to pull the gears and count teeth.
Next best is:
To calculate gear ratio for a non-limited slip
diff. is to leave one wheel on the ground (jack up the other),
turn the tire five revolutions, count the number driveshaft turns,
( include fractional turns ) then divide by 10.
this reduces your error on the estimated fractional turn by a factor of 20.
sample numbers:
a 3.11 would give 31.1 driveshaft turns.
( I'de proably extimate it at 31.125 (31+1/8)
and calc it as 3.1125 then round it to 3.11 )
a 3.12 would give 31.2 driveshaft turns.
( I'de proably extimate it 31.25 (and make a note it was slightly under)then come up with 3.125 and know from my note I need round down
to the next probable size which would be 3.12)
( even I can tell those apart )
For a quick rough estimate just turn one tire one turn ( lock the other tire)
then divide driveshaft turn count by 2.
( works ok if you just need anything close.)
it usually doesn't matter if you go a step up or down
unless you're racing, pulling heavy loads, or geared too high
or low to begin with.
just a note: every vehicle I've ever owned (6) has had the speedometer read 5-10 percent high with the original speedo gear and recommend tires.
Old Nov 14, 2014 | 07:48 AM
lnetter's Avatar
lnetter
Smile lnetter
BigBrownTruck
What speedo gear do i need for a 3.50 diff.I currently have a 3.00 and wanting to change to a 3.50.Can you tell me.
1977 F150 2wd
Old Nov 14, 2014 | 08:34 AM
stromburg's Avatar
stromburg
Originally Posted by lnetter
BigBrownTruck
1977 F150 2wd
13yr old thread and Big Brown Truck has not made a post since 2004
Old Nov 14, 2014 | 09:09 AM
ZarK-eh's Avatar
ZarK-eh
Well, since it's dug up...
Find out what you have for speedo gear now. My '78 np205 has the speedo gear (don't know what) and a changable gear inside of it, so count that inside gear too.
And then make a new thread
Old Nov 14, 2014 | 05:06 PM
flowney's Avatar
flowney
I'd say that BigBrown has hit the nail on the head. The 460 is probably the biggest part of the fuel consumption problem that you described.
One might do better with working on engine efficiency starting with a thorough tune-up. In addition to the tune-up, change the thermostat from the stock 200º unit to a 180º unit.
Assuming that this is not a 69-71 vintage 460 (check to see what the VIN says with an online VIN decoder), the camshaft timing is retarded by 7º in order to meet the 70s smog requirements. This should be be set back to 0º and, so, replacing the timing chain with a 69-71 unit will significantly improve engine efficiency. A good set of headers and adding a 1" riser under that carb if it doesn't already have one will top off the list of high return mods.
This will yield more horsepower and improve fuel efficiency without breaking the bank but the MPG gains will be modest, very modest. It will never come close to the 300 CID 6 of this era.
Old Mar 20, 2015 | 07:40 PM
rthomas1963's Avatar
rthomas1963
not to steal the thread, but i have a quick question. i have a 76 f-100 with a 9 inch rearend, on the tag it show 300 gear ratio. my question is does the 300 give you more pulling power? better fuel mileage? and is it the higher the number the faster take off speed thanks in advance.
Old Mar 20, 2015 | 09:38 PM
ultraranger's Avatar
ultraranger
A 3.00:1 ratio is a highway gear for higher speeds at lower engine RPMs but, not good for pulling a heavy trailer load.
A 4.11:1 ratio is good for pulling (or drag racing) but, will limit the top speed of the truck and the engine will be turning high RPMs at highway speeds (if no overdrive transmission).
A high ratio is numerically low --2.75, 3.00:1.
A low ratio is numerically high --3.70, 3.89, 4.11.
A non-overdriven transmission will be 1:1 in high gear. A vehicle with an overdrive transmission will have an equivalent drive ratio. This is figured by multiplying the transmission's overdrive ratio by the rear end ratio.
Example: a .67:1 overdrive ratio x a rear end ratio of 3.70:1 would have a final drive equivalent of 2.48:1 (.67 x 3.70 = 2.48). A final drive equivalent of 2.48:1 would be even higher than a rear end ratio of 3.00:1 (with no overdrive).
However the biggest difference is a vehicle with a 3.70:1 rear end ratio, with an overdrive, is going to have much better pulling/accelerating power than a vehicle with a 3.00:1 rear end ratio and no overdrive. At highway speeds, the vehicle with the 3.70 and an overdrive will cruise at lower RPMs, due to the overdrive's final drive equivalent.
Old Mar 21, 2015 | 05:40 AM
DeepRoots's Avatar
DeepRoots
Yeah, sorry bud, I don't care what gears or how many you have, a 460 in a pickup truck is going to be hard to get anything more than 12 mpg.
geez, who pulled up this thread? This kid isn't in college anymore, he's probably retired by now.....
Old Mar 21, 2015 | 06:25 AM
gatorfor88's Avatar
gatorfor88
The only place a 460 gets better than 10 mpg in a truck is on the internet.
rockertom
All Things Towing
Jul 9, 2017 08:54 AM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Apr 25, 2017 03:30 PM
bjmayberry2
WTB - Parts & other
Mar 7, 2017 07:06 AM
Gary Lewis
80
May 17, 2016 09:04 AM
newo2u
Dec 11, 2008 10:36 PM
