Automatic shift in the floor?? Anyone ever seen?
Old Jan 21, 2006 | 04:20 PM
northcreek's Avatar
northcreek
Question Automatic shift in the floor?? Anyone ever seen?
Hi, I've been a member for awhile but never posted before.
Awhile back we purchased a '73 F-250. It is automatic but the shift is in the floor. There is no sign of the steering column being changed and there is no sign of a shift lever being removed from it. The vin plate on the door shows it to have came out with an automatic, G on the plate. The vin plate is correct for the truck, I have checked the vin on the frame and they match.
It has some issues, the order of gears is backwards, park is last instead of first. There is no indicator so you just have to feel for them. They are also very close together, hard to get the gear you want.
Anybody ever seen anything like this?
Barbara
Old Jan 21, 2006 | 06:00 PM
LxMan1's Avatar
LxMan1
Someone probably changed the column to a 4-spped column that has no shifter and used a shifter from something else. The reason it is backwards is because the column shifter uses a different lever on the tranny than the floor shifter. The column shifter pushes back on the lever as you drop from park to drive and the floor shifer pulls forward.
Old Jan 21, 2006 | 06:30 PM
ivanribic's Avatar
ivanribic
If you get a chance to look more closely see if the floor shifter is a cable style or if it has a direct linkage. The aftermarket cable style shifters can be mounted in several different positions on the tranny. Whoever installed it may have just put it on backwards. A simple swap to the opposite side may fix that.
Old Jan 21, 2006 | 06:54 PM
User 71024's Avatar
User 71024
You could also fab a new lever on the tranny to reverse it, and also making it longer will spread the shift pattern apart.
Old Jan 21, 2006 | 07:54 PM
ivanribic's Avatar
ivanribic
You have to be careful about the length of the shift lever. If it doesn't correspond with the shifter then you will have just as much trouble, i.e. if you set it up at Park you may run out of travel on the shifter before you reach 1st and if it has markings they won't line up right with the gear they're in. Plus, to remove that lever you need to pull the valve body. Not too terribly tough but it is a bit of hassle.
Old Jan 29, 2006 | 05:36 PM
FoMoCoGuy's Avatar
FoMoCoGuy
I can say i've seen just that. I just bought a '78 F-100 Someone moved my colum shifter to the floor. mine isn't bad, but sometimes it slams into rev. pretty hard not sure why. Does yours do that?
85e150
Oct 19, 2010 10:33 AM
James1966
Oct 21, 2008 02:27 PM
theGman
34
Mar 15, 2005 03:23 PM
dford1982
Sep 3, 2003 02:45 PM
Mike Z
Mar 30, 2002 06:45 PM
