coil over plugs\ resistance not 5 ohms/5500
4. 7.5 ohms on primary/sec.5150
3.1.1ohms pri/5120 sec.
2..7 pri/6010 sec.
1.new
8..5 pri/5205 sec.
7..6 pri/5205 sec.
6..7 pri/5199 sec.
5..6 pri/5242 sec.
need help what range is ok , does it have to be 5 ohms on primary/5500 on secondary PLEASE HELP!!!!!!
thanks in advance
2..7 pri/6010 sec.
1.new
8..5 pri/5205 sec.
7..6 pri/5205 sec.
6..7 pri/5199 sec.
5..6 pri/5242 sec.
thanks in advance
My memory from the Haynes specs is somewhere around 0.5-0.8 ohms primary and somewhere around 5K ohms secondary.
All the COPS should be fairly consistent in this range. If you find one that is way out (for example, your #4 at 7.5 ohms primary, if I'm reading your data right), would be inconsistent by a fair amount and would probably throw a misfire code.
Have you scanned to see if any codes are stored?
took it to autozone no codes,I guess I'll just have to buy 6 new cops
It rained pretty hard last wensday thursday morning it had a bad miss
service light came on took it to autozone nothing came up
saterday I changed all plugs and replace bad cop boots and 2 bad cops checked
The Haynes book ,states 5k on primary and 5500 on secondary if the numbers don't match it said replace, can the numbers vary or not. If I don't have to replace them that 300 bucks I can use for fuel
Really doubtful that multiple COPS would fail at the same time. You said the CEL came on, but when you scanned it at Autozone, no codes were stored. I'm assuming that your CEL light is now off---correct? Did the Autozone folks re-set it for you?
We really need some more information to help pin this down. Is it running rough all the time, just at start up, during acceleration???? A COP failure should likely throw a code. If no misfires are being detected by the PCM, then I would really hesitate before throwing $50 COP replacements at the problem.
so I replaced them. CEL light is off, didn't reset Its not running rough now
I just want to know how much can the COPS vary before replacing them
I agree with PROJECTSHO89. I've seen this much variance comparing resistance across multiple COPS in the vehicle. When one fails, its usually pretty obvious when you test it.
I've also seen misfire codes thrown and it turned out to be the boot insulating the secondary spring between the COP and the plug that had failed. A lot cheaper to replace a $3 boot than a $50 COP.
