Engine/C6 Interchange
Old Jan 21, 2006 | 01:42 PM
theGman's Avatar
theGman
The 351W in my 55 panel is running on 7 cylinders. The electricals and the valve areas are fine, so I figure something internal must be wrong. The engine, from a 78 van, has seen its better days, I guess.
The C6 trans from that 78 van has been rebuilt, and I would like to continue to use it.
My question is:
Does anyone know of what will bolt up to that C6? Maybe a website with that info?
It is easier for me to find a 302 if I can't find another 351W, if I had to.
Do all 351Ws bolt up to the C6? What about 302s?
Thanks in advance,
Paul G.
Old Jan 21, 2006 | 01:50 PM
53fatfndr's Avatar
53fatfndr
You could go with a 289, 302, a 351C and 351W. Here is an application chart of sorts:
http://www.tciauto.com/ford/ford_c4_c6.htm
Old Jan 21, 2006 | 03:32 PM
merc546's Avatar
merc546
I think they made two versions of that trans one for the small block and one for the big block. My first truck had the 351W/C6 (trans was from a van). This one has a 351W/AOD.
This 351W did the same thing #1 cyl just stopped firing, never did figure that one out.
I had it rebuid and some day I plan on driving it again (this spring I hope).
Chuck
Old Jan 22, 2006 | 12:27 AM
theGman's Avatar
theGman
Thanks for the info; I didn't realize the same C6 fit all those.
The reason I didn't realize it is that, when I had one rebuilt to mate up with a 390 from a '68 Galaxy, the holes didn't line up. I luckily had the original trans from that 390, so the shop switched the innards.
georgiafordman78
15
Oct 2, 2006 07:54 PM
Jamie Miles
Mar 17, 2005 11:50 PM
ortega
Engine Swaps
Feb 9, 2005 09:36 AM
BlackenedBlue77
Nov 14, 2001 03:26 PM
